Question about Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer
My Xerox phaser 3300 mfp scanner is locked. How do I unlock it?? Thanks so much.
Posted by mailnancyhal on
Anonymous
    New Friend:
Look under the scanner area-Where the finished paper copies come out- There is a little green Tab. Pull Green Tab forward.
Posted on May 21, 2012
  • 3 more comments
  • romeopiper
    romeopiper Jan 28, 2013
    this was so helpful, thank you so much life saver
  • Omar Jun 05, 2013
    Thank you soooooooooo much.
  • martino
    martino Oct 15, 2013
    Thanks Very Much..save me a couple of hours pulling my hair out !
  • Al B Nov 09, 2013
    Even after pulling the tab, the scanner will still be locked. You have to turn off the machine and then turn it back on in order to reset it
  • Anonymous Aug 18, 2021
    Mi escaner dice error cuando voy a copiar ayuda
5 Related Answers
sushanta halder
  • 89 Answers
SOURCE: Internal Error wer off/on BB_DataMgr.c
write the hole message which is displayed on the screen.
Posted on Jan 12, 2011
Anonymous
  • 23 Answers
SOURCE: xerox 6110 MFP scanner locked
on the left side of the device should be a mechanism to release the scanner
Posted on Feb 27, 2009
SOURCE: Hello! I have the xerox phaser
Power off then on. If this doesnt clear the problem the power supply i going faulty and will need to be repaired..
Posted on Feb 23, 2011
Anonymous
SOURCE: How do I unlock the scanner on the xerox 3300 mfp?
DEBAJO DEL PANEL DE MENU (DONDE SALE EL PAPEL), HAY UNA PALANCA CORREDISA QUE BLOQUEA Y DESBLOQUEA LA LAMPARA DEL ESCANNER, ESA ES LA SOLUCION.....
Posted on Apr 27, 2011
Solo hay que desconectar la bateria interna que esta debajo del panel por un momento , conectas la energia sin conectar la bateria , si todo esta bien vuelves a conectar la bateria y ya no te dara mas problemas.
Oscar M
Posted on May 04, 2011
How to reset toner chip Xerox Phaser 3300 mfp
Purchase a new toner cartridge from Xerox not a hookie one from fleabay.
I have a Xerox Phaser 3300 MFP wITH BLANK COPY i CHANGE MAINCONTROLLER, LASER UNIT pOWER SUPLYANY iDEA
If you can print any internal report from the machine or from your computer then the problem is in your scanner.
If you cannot perform any print function then probably the laser assembly has failed.
I work IT Support. I have a user that cant send/receive fax from xerox phaser 3300 mfp. They can scan/print fine. Thoughts?
check the fax line. Plug that line into the regular fax machine to see if you can receive/send from there. What where you should start. Thanks
7helpful
Internal Error wer off/on BB_DataMgr.c 487 T in xerox phaser 3300 mfp
Oscar M
We have hosted Exchange email and I've been tasked with getting a xerox 3635mfp to scan to email. So far no luck even though I believe I've input all the correct information.
for scanning with Xerox MFP it is convenient to use MFP TWAIN Importer (http://www.scanworkssoftware.com/twainimportermfp.aspx ) It allows scanning from Xerox MFP directly to user's workstation with secure way and without any additional efforts.
Phaser 6110 mfp , the display say that the scanner is locked , I don't have the manual with maiself
Check here.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=465,E=0000000001733349606,K=391,Sxi=10,Case=obj%284350%29
34helpful
2answers
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Xerox Phaser 3300mfpv/x Print Copy Scan Fax All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Ekse
Mehandi Husain ...
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
