Toys Logo
Question about Lionel Toys
I have a Lionel 2055 post war train that I have not used in many years. I am setting it up around the Xmas tree. It ran well on the carpet when I tested it out but not around the tree on the hardwood floor the front wheels come off in the corners after 5 minutes or so of running. I've lubricated the engine and wheels. The track configuration around the tree is the same as when I tested it on the carpet. Can you give me some ideas on what to try to keep the front wheels on the track? Thank you.
Posted by jarvis680 on
Traindoc
    New Friend:
  • 38 Answers
Check to see if you picked up any fibers on the wheels or axles from your carpet running. Also check to be sure the pilot truck can swing freely from side to side and is not bent. There is also a light coil spring on the front truck pivot pin. Be sure that the spring is there and is not damaged. Another thing to check is the drawbar between the locomotive and tender. Your front wheels may be getting lifted off the track because the rear of the locomotive is getting pressed down. This a soft carpet may compensate for this but not a hard surface. Run your train at a speed where it derails and look closely at the locomotive to see if the rear is being pressed down.
Posted on Sep 02, 2017
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Hello: Train won't move
CHECK FOR SWITCH ON BOTTOM OF TRAIN
Posted on Dec 07, 2008
Anonymous
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
Anonymous
  • 5158 Answers
SOURCE: Thomas the Tank Engine, Sodor Post Office Train Track
http://www.thomasandfriends.com/usa/news_product_info.asp
scroll down the images till you see the set that they have. click on it when the page opens look for instructions... click on that it should have them. note i did see at least one recall notice so make sure that doesn't involve the set you have
Robert
Please take a moment to rate this solution thanks
Posted on Jan 29, 2009
Anonymous
SOURCE: Need help setting up Lionel North Pole Central
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
Posted on Dec 04, 2009
Anonymous
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Posted on Dec 27, 2009
1helpful
How do I connect the Lionel #76 warning bell & shack?
Lionel#76 accessory is a pre-war item, so instructions for it are scarce. I suggest you read pages 12 - 26 of the attached pdf and hook up the #76 following the directions for one of the automatic signals.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Where can I get a set of 0-9 rubber stamps in the correct Lionel font and size for re-numbering Lionel pre war STD gauge brown State Pass boxes? Thanks, GG
Mania Trains in NJ has repro stamps for Pre-War trains...may have stamps for the boxes as well. Many of the stamps came from Jerry Butler....Excellent products
Olsen's trains in Ohio may be a second source
Jul 02, 2014 • Toys
Lionel 313 bascule bridge
It sounds like the counterbalance spring is loose or disconnected. I would rather add weight to the counterweight box to take some load off of the motor...Use fishing sinkers, one or two rolls of pennies or equivalent. Also do not overtighten the spring you will warp the base of the bridge.
Check out these Lionel Customer Service Videos.
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6334
http://www.lionel.com/CustomerService/service-documents/video.cfm?documentID=6337
When the train is heading around the track, it stops on the curve, and will only start again, when you turn it off and back on??? Does this on both ends when turning the corner? Can you halp??? Tha
Check to see if the train is lifting off the track on the curve and the roller is not making contact with the center rail. Run the engine alone slowly and try both forward and backward.
Can I use the cw-80 transformer on any Lionel train set from year 1948 to the preasant , thanks George
You should be able to. The Lionel transformers all put out AC power, not DC and many Marx and American Flyer transformers will work too. The real question is total amount of power being drawn and whether or not you have the wattage to match your engine and accessories. With the CW-80 though, it should put out plenty. I run my pre-war 1666E engine pulling a full compliment of metal cars with no problems using a CW-80.
3answers
Runs only in reverse i have other pre war 1681e does the same
Have you changed transformers? You can also make a Lionel run in opposite direction by using the throttle control...just go to stop and then to power and then back to no stop and right to power. That often works.
Top Lionel Toys Experts
Marvin
Marvin
Paul Bade
Are you a Lionel Toy Expert? Answer questions, earn points and help others
