Its sounds like you are trying to take out the drain pump to clear the impeller of broken glass ect... Make sure your taking out he right one, because the drain motor is the small on one, the bigger pump is the circulation motor and if you disconnect that tube you will end up buying a new sump/pump assemble. The drain motor should have a clip that you push down and while turning the pump clockwise to take off. Once off you will be able to clean it out. Please look at my quick tip also for some common drain problem issues
http://www.fixya.com/support/r7229617-quickest_way_fix_drain_issue_dishwasher
I wish you the very best!
Please rate me "4 thumbs" if I helped you, thanks!
