Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Trying to ajust the screen, lost manual. I tried the aspect but could only get standard, and expanded zoom. Still too large for the screen. ?? help!
Anonymous
    Brigadier General:
  • 8,909 Answers
A manual should be available on Hitachi's web site. That will help you get the correct size.
Posted on Dec 15, 2010
How to resize picture on a magnavox mwc20t6
Look for a setting called Aspect Ratio. It will include options like 4:3, 16:9, Zoom 1, and Zoom 2. Then click through the options to select the correct one for your program. Usually older SD programs will use either 4:3 or Zoom 1, while HD programs will be set to 16x9 for Widescreen hi-def viewing. There should be a button on your remote labelled Aspect Ratio or Picture that can toggle through these image modes.
Nov 26, 2014 | Philips Magnavox MWC20T6 TV
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
Picture size too large, especially horizontal
Try to press the zoom in or zoom out button on the remote control
if that didn't work, try to check the aspect ratio of your TV. You can see the aspect ration on the menu. set it to 4:3 standards and if it's HD TV set it to 1080i.
Apr 17, 2011 | Televison & Video
How do I change the format on the screen to fit my TV, the format is too large and the picture is getting cut off on both sides
U using the tv original remote wright?Yes.Check ur tv remote control for a button like View Mode,Aspect Ratio,Picture Zoom,P.Size.Pushes one of these buttons to ajust the tv picture screen sizes.
Mar 25, 2011 | Televison & Video
My tv screen is zoomed in how to zoom out
  1. Check the TV to see if it has a ZOOM / WIDE option or control for adjusting the aspect ratio; if so, try setting it toNORMAL .
  2. NOTES:
    • If there is a SCREEN MODE button on the TV remote control, you can press this button until NORMAL is selected.
  3. If using a cable/satellite set-top box, DVD player or digital video recorder, check the device for aspect ratio controls and try selecting a different display option.
Jan 16, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Jvc 57 inch tv. kid did something to change picture size. now too large and bottom is cut off. aspect button on remote when pressed shows a red circle with a line through it.
what was pressed on the remote is "Zoom" button, that's why the picture size is large.
So try to identify the Zoom button on your remote by pressing every button on your remote in order to get the zoom button function.
I hope you understand my message.
Good luck.
Apr 13, 2010 | JVC AV-28-BD-5-Bl 28" TV
THE PICTURE IS OUTSIDE THE FRAME
you have to ajust the zoom...or aspect ratio...usuallly there's a one touch button, or go into the menu,then to picture settings..You should be able to adjust it there
Oct 23, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
The problem with my NEC 68T90 TV is that the screen resolution is not correct. At 4:3 ratio, I can't see the sides of any video or TV program that I'm watching. Is there a problem with the hardware?
Try the aspect button on your remote, or if you have this hooked up to a cable or satellite converter, there are screen resolution preferences, you can change the screen resolution here, go the the menu portion and look for video/audio field
May 07, 2008 | Televison & Video
My screen had gone out fit its expanded and now its out of view
Screen size selection sometimes called aspect ratio--Check each menu/page selection to gain understanding of each function/feature.Consult owner/operator manual.If not available,WWW-- Akai Owners manual.
Oct 05, 2007 | Akai CF2791 27" TV
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
