Precor Error 05, Key Depressed at Power Up
Probable Cause
1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Probable Cause
Corrective Action
Probable Cause
Corrective Action
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
On a vista system, enter your 4 digit code and press the 9 button. The keypad should read: Disarmed Chime. The keypad should ding ding ding when a door is opened. To turn the chime off, enter you code and press the 9 button again.
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
Ordinary "desktop" keyboards have a separate "keypad" (slash, star, minus, plus, enter, dot, and 0 through 9) in the same layout as a "traditional" adding-machine.
However, to keep the laptop's keyboard much smaller, those keys are superimposed on the right-hand side of the "standard" keyboard.
So, press "NUMeric LOCK" to use the "keypad" layout, and press it again to use the "standard" letters (I, O, P, K, L, M, et cetera) on the keyboard.
You either have a bad Flex Cable or Minor water damage under the keypad. It needs to be opened and inspected. If you are a little handy, the N95 is not that difficult to open. Search youtube for a opening video of the N95 and inspect the flex cable and its endings then under the keypad itself for signs of corrosion
