Washing Machines Logo
A
Anonymous Posted on Dec 15, 2010
Hello i have a MAYTAG washer top loader/ model-PAV2300AWW. The washer will not agitate but will drain and spin with no problem. About give or take six months ago the transmisson gears inside went on it, I replaced it with the up-graded heavy duty trans. im kinda guessing its either the motor or the timer. ( i replaced the timer 2 years ago) Thanks for anytype of help.
Anonymous
Level 2:
  • Expert 57 Answers
  • Posted on Dec 15, 2010
Anonymous
Expert
Level 2:
Answers
57
Questions
0
Helped
10335
Points
176
Does the motor sound like it is running? Also trying jiggling the timer in agitate and seeif it starts to agitate. If it does then a bad timer if not look else where possible transmission problem again.
1helpful
My maytag pav2300aww will not spin at all yet it agitates and drains well I was told to clean the agitator so I took it off yet the washer still don't spin the switch look wore out to me so I by-passe
Check the water level sensor and the lid safety interlock. Many washers will work fine with the lid open EXCEPT during the spin cycle, so this is the first logical place to look. Try bypassing the lid safety interlock switch.
2helpful
My maytag washer model pav2300aww will not spin even though it agitates and drain but when it comes to the spin cycle it just kind of hums I looked at the bottom of the washer while it was in spin cycle...
Possible the revolution takes place on the top end of the pulley and belt but the centre stem of the agitator is not moving or it is slipping. It can be due to friction in the stem of the agitator due to clogging of dirt and the best option is to remove and clean the agitator.
I have a maytag pav2300aww top loader it fills up ,it spins and drains but it wont agitate i checked the pully it moves only one way ,is the trans hot ,can u turn it both ways
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya
3helpful
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
2helpful
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
WASHER WON'T WASH
Check the pully Cam if thats good. You have a bad tranmission. This warr. for ten years
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
3helpful
Washer won't stop filling with water
In yor machine control panel you have A part called a pressure switch or water level switch. that controls the water level and tells the timer to start aggitating .If the part is bad the machine will over fill and keep running the water!!
2answers
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Top Washing Machines Experts
john h
