Hi, i have an Acer Aspire 5735. Most of the screen has gone black apart from about 3 inches on the left hand side which are perfectly normal. I've connected the pc to my lcd and it works fine on there. Can anyone help please?
Just to Add to the above the desktop does sometimes show completely for a couple of seconds or the black part can sometimes be whiteJust to Add to the above the desktop does sometimes show completely for a couple of seconds or the black part can sometimes be white
You can't post conmments that contain an email address.
Re: Hi, i have an Acer Aspire 5735. Most of the screen...
Connect your laptop to an external monitor and I expect you will find it is displaying OK on the external screen. Browse ebay for a replacement screen.
If this just comes up with the Acer Pan-Am home page, and not the exact driver download page, for the Acer Aspire 5735 that I linked, do this,
1.In the left hand light blue column, click on Drivers & Downloads.
2.To the right will be a small window, that states -> Select Product Family. Click on Notebook.
3.Another small window will come up -> Select Product Line. Click on Aspire.
4.Another small window will come up -> Select Product Model. Use the slider on the right of the Select Product Model window. Click on the down arrow of the slider. When it scrolls down to Aspire 5735, click on it.
(Make SURE you do not have the Aspire 5735Z. Look on the bottom of the laptop. This model number will be stated, if so. If it is the Aspire 5735Z, click on it)
Once you click on the Product Model you have, the drivers will be shown at the bottom. Click on -> Lan......Marvell......LAN Driver (LAN = Local Area Network. This is your Ethernet driver)
You need to give me a few more details,is the screen blurry on one side,and brighter on the other?,two, are you using a some special graphics software that might not be ment for your computer,you should plug a monitor into your laptop to see if it gives the same affects,and press the window or function key, and one of the monitor symbols on your keyboard at the same time(,they are coloured the same as the function key),to change your main screen to a plug n play one,if the screen comes up with the same affects then it is a software problem,you might have to uninstall the software that is causing the problem,or two if is comes up perfectly,then it might be a hardware problem,you might have to bring your laptop to a pc mechanic to be degaussed,this puts a charge on your laptop screen and it costs more to do than replace one,most plug and play monitors can degauss them selves,others need to be done manually,unfortunately laptop screens have to be taken apart to be degaussed,i know its silly.if its not blurry then it cant be hardware problem.its one of your graphics settings.
