Sound like the gas valve or the thermostat. In other cases, its more than likely your clock/oven control board thats bad; you would need a volt meter to check for 240 volts across your bake
element terminals, where the electrical connections hook-up to it. If no
240 volts, then the problem is you electronic control board is bad as
well.
Hope helps.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
The ignitor is not working right and is going bad....
have
the repair man replace the ignitor, or DIY....
Check out this tip
about your problem...
Oven not Working or Oven
not Heating
Oven
Problems Replacing
the Igniter
heatman101
Note this is a GAS range, not electric. A wire fed element would be a good GUESS for electric. This is GAS.
