Ovens Logo
Question about Candy Ovens
My Candy C5006 electric cooker has one hob ring which when turned up to a high setting trips the electric fuse, all olther hob rings work ok.
ashburton
  • 417 Answers
The ring that causes the trip out needs to be replaced with a new one.
Posted on Dec 15, 2010
No power to oven at all. Checked trip fuse and all ok there.???
It is likely the control board. You need a technician. They are expensive so you need the correct diagnosis and warranty on the work.
Jan 03, 2023 • Ovens
CANDY 2100 W FC5 602 XE TIMER NOT WORKING
Hi, Try taking the back off (sometimes the have have clips)?
Aug 08, 2021 • Candy Ovens
We have a belling induction cooker. The trip blew now E5 is flashing on the hob, only two of the hot plates are working and neither of the ovens are working. It's only 2.5 years old.
Unfortunately, Induction hobs on domestic cookers have always been a problem. A single, one ring catering hob is $1,200 and is expected to last 2 years in an industrial environment.
There are two videos here, but I reckon you will need a service call.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01r2k0Xw_ZCF69PXpLMkc_N2QzdIQ%3A1608069741109&ei=bTLZX5KRBtfRtQb9wp6IBQ&q=belling+induction+hob+e5+error+code
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 • Ovens Ovens
Twin ovens stopped working
Hi, Have you altered the time clock on the cooker? It is possible that the clock/timer is set for 'Auto'
Dec 26, 2013 • Caple Ovens
2answers
Hob on my hotpoint oven trips my RCD
It is either a faulty ring, or the regulator that controls it is faulty.
You really need a meter to test the ring with to be certain which part is faulty.
Hope this helps.
Feb 21, 2010 • Ovens
25helpful
Candy sprinter hobb all on L locked?
Ours started doing the same Displaying L on four hob displays. I figured to press the bottom right hob and the minus button at the same time should unlock it.
Thanks
Trev
Oct 07, 2009 • Candy Ovens
1helpful
Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
2helpful
2answers
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 • Ovens
Top Candy Ovens Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
ADMIN Eric
ADMIN Eric
Are you a Candy Oven Expert? Answer questions, earn points and help others
