Question about Price Pfister Home
I can think of a few possibilities. 1) Something is blocking the hot water in to the mixing valve. Fixing this would probably mean cutting out the valve (then redoing the water lines with a new valve (possible option)).
2) The hot water line is losing too much heat going to this second faucet. (If the two tubs are on different floors this is more common. Many places are plumbed with one line with Ts to all fixtures.) Insulating the water lines might help; alternatively an point of use water heater would help.
3) The hot water and the cold water in are reversed. (Test by leaving the water on full cold and full hot for a few minutes each.) If you get full hot when it should be cold, valves with a cartridge are easy to fix. Open the valve assembly, remove the cartridge and reinsert it after turning it around (side closest to you when you removed it goes in first). Otherwise, the incoming plumbing needs to be redone at the point where the cold and hot lines come into the shower.
I hope this helps.
Posted on Dec 15, 2010
Mar 12, 2011 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
Feb 19, 2011 | Price Pfister Plumbing
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Feb 13, 2011 | Moen Posi-Temp Single HandleTub And Shower...
Oct 09, 2010 | Delta & Single Handle Shower Faucet
May 19, 2010 | Danze & Single Handle Tub And Shower...
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
Mar 03, 2010 | Delta & Single Handle Shower Faucet
Mar 01, 2010 | Moen & One Handle Tub & Shower Faucet
Aug 05, 2009 | Moen & One Handle Tub & Shower Faucet
Mar 21, 2015 | Price Pfister Home
Dec 15, 2014 | Price Pfister 808-TMYY Hanover Single...
720 people viewed this question
