SOURCE: Garmin Nuvi stopped working and won't restart
Got a Garmin Nuvi 260. Same problem. I read the booklet. There's a reset button on the bottom. Disconnect from power. Push the reset button. Connect back to power. Now it works. The reset button is tiny and looks more like just text on the bottom sticker than it does a button. But push it anyway.
SOURCE: My Garmin 1300 had its maps earased
Hello, take the sd card out of the unit, press the reset button if one is available, if not hold the on/off button for 10 seconds and then reinstall the sd card and switch the unit back on and hopefully the maps should reload
SOURCE: garmin 1300 stuck on maps loading frozen
I had the same problem with a 1300 unit and a car charger. After holding power button for 10 seconds it would begin to start, but get stuck while saying "Loading Maps." and then it would shut off again.
I fixed it by plugging the unit into a computer USB port. It then did it's PC connection startup as usual, which leaves a connection icon on the screen. I gave it a minute and then unplugged it from the PC. It then restarted and booted up properly.
Hope this helps.
SOURCE: Garmin nuvi 1300 won't turn on!!!
we are having the same issue with ours - sometimes it will power up no issues and other times it the power button won't work - seems lots of this brand, different models all have the same issue - not sure what the solution is though
SOURCE: my garmin nuvi 1300 shuts
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
