Question about Reddy Heater-170,000 BTU Kerosene Deluxe
C5 code and full of diesel fuel will fire up and run for about 30sec first time and 5 sec. after resetting
Posted by terryljackso on
1 Related Answer
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Reddy heater 55000 BTU running diesel fuel. Turn
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Feb 20, 2011
Accidentally put unleaded fuel instead of diesel in 2013 D22 drove approx 10k
Drain the fuel out and flush the fuel lines and the filter. Failure to purge the unleaded fuel from the system can destroy the engine due to severe pre ignition.
Feb 18, 2017 | Cars & Trucks
Tip
Remove 30sec time restriction IN RAPIDSHAR
Just go..& type in address bar. <br /> javascript:alert(c=0) <br /> REMOVE rapidshare 30 sec waiting time....just type or copy & Paste..above java code....in addresbar & remove 30sec wait time... <br />
on Apr 04, 2011 | Computers & Internet
Chainsaw wont stay running Runs 30sec to about 1 1/2 min seems to be starved for fuel
Initial carb setting is 1 full turn out on both low and high side and retry. If no difference, then turn the low side out and additional 1/4 to 1/2 turn CCW. If that makes no difference, then it's time for a carburetor rebuild.
Feb 24, 2015 | Garden
96 6.5 deisel fuel problems 3500 truck
there is a fuel line return valve on most diesel check and replace
Dec 01, 2017 | Chevrolet Malibu Cars & Trucks
How do you get the change fuel filter off on a 06 chevy diesel
You could try... Turn the key on (engine off) and press the gas pedal to the floor 3 times within 5 secs of turning the key on. That's how u reset the oil change indicator may work for the fuel filter
Dec 26, 2013 | Cars & Trucks
I have a McCulloch Model FR 2.3 18 in. chainsaw that will fire up and run for approx 30 secs. and then shut off. If I pump the primer bulb twice, it will fire up again for approx 30 secs. I'm ve
This is oviously fuel starvation, the first thing to do before speding too much time on it is to replace the fuel filter in the fuel tank, hook the hose out with a piece of bent wire, pull the filter off and replace, as a quick test pull the filter off, let the fuel hose go back into the tank, make sure the tank is full, now try. Do not leave like this you must fit a new filter.
Mar 30, 2013 | Garden
What's your problem?my citroen c5 diesel 53 plate 2.0 ltr HDi comes up with, anti-polution fault, on dash, with service and engine management lights on, then it goes into emergency mode, then will
Empty the tank completely. The additive you put in with only a gallon of fuel is not combustible and won't run. Bleed the system, after replacing the filter and refill the tank with fresh fuel by cranking and open all injectors one at a time, starting with the one closest to the injector distribution pump, until you get clean fuel from each injector. It will start and run shortly. Never put any additive in the tank without the tank being full of fuel after the additive is put in. All these additives, like I said, are non-combustible.
Nov 28, 2017 | Cars & Trucks
2001 dodge 5.9 diesel Cranks for 20 to 30 sec to start in morning
You have fuel runback.Replace the injector leak off pipes then try.If this does not work then have a non return valve fitted to your fuel supply pipe close as possible to the punp.Hope that was helpfull good luck.
Aug 01, 2009 | 2001 Dodge Ram 2500 Truck
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
150 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
