SOURCE: Hello
try this link http://support.dlink.com/supportfaq/DisplayTemplate.aspx?TemplateId=1443235
SOURCE: Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
SOURCE: setting timezones on Netvanta 3200 router
clock auto-correct-dst
clock timezone -5-Eastern-Time
clock set 23:58:00 05 May 2010
SOURCE: I am trying to use
Hi, well there are just so many "Issues" with VPN's that really it is a case of working through a troubleshooting procedure to isolate and fix the problem.
To this end I am giving you a couple/few web links to assist you. As you correctly state often it is NAT issues.. however this isn't the only thing that can stop things from working...
Please visit each website, by using these sites I am sure you will be able to sort you problems out, just be methodical, and work through the troubleshooting steps...
http://articles.techrepublic.com.com/5100-22_11-5845666.html
http://help.expedient.com/vpn/vpntrouble.shtml
http://technet.microsoft.com/en-us/library/cc958057.aspx
