Question about Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch
How to undo a tag watch clasp - Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch
Posted by robert_chipc on
5 Related Answers
Anonymous
SOURCE: I got a tag watch
depends on the model on mine you press the two tabs on the side in then the part with Tag Heuer goes the opposite way first, to the part with the TH symbol on it. Mine was a bit difficult when new but soons works just fine
Posted on Dec 25, 2008
Anonymous
SOURCE: Watch clasp on Tag Heuer
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Posted on Dec 26, 2008
Anonymous
  • 61 Answers
SOURCE: The folding deployment clasp on the bracelet/strap
The newer straps on TAG are generally wider than the professional series and the cost of a new genuine TAG heuer clasp or bracelet may easily exceed the costof buying an entire watch of that series used.
I recommend searching for an after-market strap/ buckle usuing your case back numbers as the search criteria.
Posted on Oct 17, 2009
Testimonial: "Thanks - I'll try that!"
Anonymous
SOURCE: OK I'm an idiot.
same problem, anyone know?
Posted on Jul 31, 2010
joeguest2
Joe2
  • 2080 Answers
SOURCE: I have an Ecclissi watch.
Often times these watches come with magnetic clasps and a little safety chain. Just try pulling the magnets apart firmly.
See an image at the following link:
http://www.preciousaccents.com/22640-11-p-Ecclissi-Marcasite-Watches&show=.html
Good luck.
Posted on Apr 14, 2011
Clasp for Tag Heuer aquamarine watch BA0751
Once you have the part number you can search ebay and if lucky you will find the clasp there.
Jan 22, 2013 | Tag Heuer cj1110.ba0576 Wristwatch
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
Tag Heuer "link" woman's watch-- can't open clasp!
You just have to pull with more force. Decent watch brands always make clasps very tight.
Apr 15, 2011 | Tag Heuer Watches
I accidentally stepped on my Tag Heuer TWWK1120.BB0314 bracelet now the clasp doesn't click and lock. Do I need to replace the whole bracelet or just the clasp.
Has it broken, or just been bent out of shape??? If it is just bent you could possibly take it to a TAG repairer or a watch maker to get it adjusted
Mar 25, 2011 | Tag Heuer WK1120.BB0314 Wristwatch
I bought my bulova 96R105 today, the jeweler placed it on my wrist, but now I can't undo it. Please help
It may have buttons on the sides of the clasp that you must press. If you do not see the buttons on the sides of band, it is a friction fitting, and you must pull on one or the other side of the "butterfly" clasp for it to release.
If you see a large outside clasp, there will sometimes be a fold over safety. This is called a tri-fold clasp. You must pull up the hinged clasp one direction, then the main clasp the other direction. A bi-fold clasp has no safety, and can be pulled one direction to open.
Feb 04, 2011 | Bulova Diamond Accented Calendar #96R105...
The folding deployment clasp on the bracelet/strap for my Tag 1000 series ladies watch has broken. Might a replacement clasp from any of the current tag models fit?
Oct 17, 2009 | Watches
How to make the clasp on a Rolex 118238 president tighter
there is a little tab on the strap that need to be bent slightly to tighten the clasp.  Most jewelers will do this for free.
Jan 12, 2009 | Rolex Day-Date President 118238 Wristwatch
Apr 24, 2008 | Tag Heuer WK1111BA0317 wristwatch
My watch dosen't fit
Have a look at bracelet clasp exetnder from RTL Watches
Jul 28, 2007 | Tag Heuer Link CJF2114
Tag Heuer Link Automatic Chronometer WJF5112.BA0570 Wrist Watch Logo
1,489 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
