turn up auto operation time (knob on side) not thickness knob to a time more acceptable to you (or it can be malfunctioning too) just by noting auto slice mode tells you it runs on a timer , as it auto advances product to make even thickness slices each time
The blade may require cleaning in between usage as the oils and sugars are solidifying on the blade from previous usage causing the meats to adhere to the blade when sliced.
To operate the slicer in Automatic mode . . . Rotate the Speed Selector Knob to the desired
speed; make sure the Carriage is in HOME position (all the way forward); make sure the Lever
is on the Manual position (pointing down); turn the slicer on; start the carriage drive unit by rotating the Lever to the Automatic position (up and to the right).
Either of the two speed selections can be used to begin Automatic mode. The speed can be adjusted
at any time by rotating the Speed Selector Knob.
To stop the drive unit, rotate the Lever down and to the left - to the Manual position.
If you slicer is set on proper automatic mode and still not running on automatic mode then the problem relates to internal motor or the selector knob.
But try reset before this.
Push the reset button underneath the slicer near the right-front foot if the carriage motor overloads.
The reset helps in some problems.But if its not helping then internal connections of selector knob has to be checked.Of the same with motor,the connections of motor to the selector for automatic mode has to be checked.----------------
This will help.Thanks.Helpmech.'
