Question about Kodak Carousel 4400 Slide Projector
I cannot get my projector to stop rotating the slides tray. No matter what setting the projector is on, it runs on "fan mode" and keeps rotating the tray. The Kodak Carousel 4400 that I have is well over 15 years old. Is there a solution to this?
Jim Auburn
    President:
  • Kodak Master
  • 412 Answers
This problem is caused by the cycle contact requiring an adjustment. Unplug the projector, remove the lamp module, turn the projector upside down & remove the bottom cover. Near the center of the projector is the Slide Change Mechanism. At the center of the mechanism is the Camstack. Refer to the illustration for the correct position of the clutch contact to the cycle pad. You will have to bend the clutch contact wire (GENTLY) a little bit, then plug in the projector & cycle it Forward a few times and check the position of the wire to the pad. This adjustment usually takes a trained hand a few times to get the position correct. If you don't want to tackle it, contact a factory-trained repair dealer for assistance. Good Luck !!I cannot get my projector to stop rotating the - jauburn_4.jpg
Posted on Dec 21, 2010
I can not remove the slide tray need help please thanks
Not seen one for years, but from what I recall, the slide tray can only be dismounted from one position. Try either rotating the tray (carefully !) by hand until it frees, or else turn it on and use the remote control to rotate the tray one slide at a time until you can lift it free. Once you know the correct position, mark the tray and the projector so that you don't have this hassle in the future.
The carousel in my slide projector is stuck
I presume you are talking about a kodak projector. Look down into the center of the slide tray as it sits on the projector. There may be a small slot. Get a quarter, put it in the slot and turn it clockwise (?) a little, then lift the end of the tray furthest from the stuck slide. The tray should lift away. WITH THE RING ON, turn the tray over and rotate the metal bottom of the tray until it clicks, returning it to the "zero" position. Turn off the projector (if it's on) and retrieve the slide. Turn the projector on and hit the FWD button to get the arm situated correctly.
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
8helpful
I am unable to latch the slide tray into my 760H Kodak carousel projector. The lamp and fan are working. Any suggestions? Thanks
Terry,
I think I already answered this one, but it still appears in my question cue.
Make sure the locking ring (on the top of the tray) is on TIGHT on the slide tray. Turn the tray upside down. Rotate the metal plate until the arrow stamped into it lines up with the notch on the bottom of the plastic tray. That should solve your problem. Jim
2helpful
My Kodak Carousel 650H has a stuck slide and the tray won't move. The stuck slide is lined up with the "gate index." I tried releasing the tray but only one side of the tray releases. The...
Two steps.
1) Look down into the center of the carousel. There should be a round, flat silver knob with an elongated notch in it. Take a coin (US 5-cent piece or similar) and use it to turn the knob. This releases the catch on the metal plate under the projector. You should then be able to lift the carousel off. Be careful: some slides will fall out as the slot is not aligned with the carousel body properly once you do this.
2) Make sure the locking ring on top of the carousel is in place (or else take out all your slides. Turn the carousel over and gently rotate the metal plate covering the bottom of the carousel into position. You will hear/feel a "click" when it's in place.
The projector may have jammed because there are two slides stuck in the viewing slot--check for this before you put the carousel back on the projector. If it jams a lot the metal plate under the carousel may be bent.
7helpful
Projector just jammed. cannot remove carousel or advance or reverse direction
This is a pretty common problem. First, make sure the locking ring on the top of the slide tray is on tight! Next (power off), place a quarter in the center hub of the projector and turn (while lifting the tray). If you have a newer projector it will have a plated slider that you can move with your fingertip, instead of the quarter. Lift the tray off the projector and turn it upside down (now you know why I said "make sure the locking ring on the slide try is on tight"!!). Remove the slide in the gate of the projector and return it to the slot visable through the plate on the bottom of the tray. Keeping the tray upside down, pull back on the short metal spring near the outer edge of the tray. Holding that spring in, rotate the metal plate until it gets to the "zero" location on the tray. Release the spring.
Now turn on the projector (without the tray) and cycle it 3 or 4 times in Reverse (that clears the jam). Replace the tray and you are good to go!!
By the way, closely inspect the corners of your slides. If they are de-laminating, or if the entire slide has a "bow" to it, you will continue to have problems with your 140 Slide Trays. They were designed to hold the absolute maximum number of slides, with very little margin for error. If your slides are like mine, you may be better off moving them to 80-Slide Trays (available cheap and in great numbers used on the internet.
If this has helped you, great!! If you have more questions, please ask!! Please take a minute and give FixYa some positive feedback if I have helped you!
Good Luck !!
Jim
3helpful
We have a carousel and the tray will not rotate - could you give us a hint of what to try. We would like to view so we can move the slides to DVD. Thanks
First of all: Does this happen with every tray? If not, check the suspect tray's locking ring to make sure it's tight & secure. Then turn the tray upside down & make sure the bottom plate is in the "zero" position. Try the tray again.
Next: Is the motor running? Can you feel air being exhausted from the rear of the projector? If so, try cycling the projector with no tray on it. If the levers move in the cut-out on the top of the housing, try pushing the "Reverse" button for at least 4 cycles (this clears a cycle jam) and then try to place the tray on the projector & cycle it. If you still have no luck, then it's time to take the projector to an Authorized Repair Dealer - the projector requires servicing.
5helpful
Removed carousel midway by lifting release as a slide fell down,
With the tray removed, cycle the projector in Reverse button 5-6 times. If it is just a mechanism jam from removing the tray mid-cycle, this will cure it. To set the tray back to Zero, FIRST make sure the locking ring is in place and tight on the top of the tray. Then turn the tray upside down & release the latch and rotate the bottom plate back to it's home (Zero) location.
12helpful
I'm having a problem loading a tray onto my kodak carousel 4400 slide projector any solutions?
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Kodak Carousel 4400 Slide Projector Logo
Top Kodak Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
