Question about Huffy Pro Thunder Boys 16-Inch BMX Bike
Seat assembly came apart out of the box and I need direction on how to assemble the seat mount components
Anonymous
    Guru:
  • 347 Answers
Please go to my tips and tricks page. There are links to huffy's website for on-line assembly instructions and detailed owners manuals. Good website.
Posted on Dec 15, 2010
How to change high mount brake light bulb in a 2002 lincoln navigator
Instructions
    • 1 Open one of the rear doorsicon1.png of the LS. Position yourself on your knees in the back seat, facing the rear deck or rear dash.
    • 2 Remove the cover from the high-mount brakeicon1.png light assembly, by hand. Pull the cover toward the front of the vehicle. Do not pull extremely hard, or you will break the clips that mount through the deck from the trunk.
    • 3 Pull the old light bulbsicon1.png out of the high-mount assembly. Wrap the new bulbs in a paper tower prior to picking them up. Insert new bulbs into the assembly, by hand. Do not touch the bulb lenses with your hands directly.
    • 4 Install the high-mount cover onto the rear deck and push the cover toward the rear glass to lock it in place.
Read more: http://www.ehow.com/how_10060583_replace-upper-brake-bulb-2001-lincoln-ls.html#ixzz30cNQ559F
May 03, 2014 | Cars & Trucks
Door switch assembly
That is going to be directly in the inside of the door opening itself. You will need to take apart possibly some of the front panel to reach all of the components.
Jul 19, 2012 | Frigidaire ATF6000ES Front Load Washer
How to change front power seat track worm in 1993 landcruiser
Lift the front edge of the seat bottom by using the regular power seat switch. Take voltage readings of the seat slide motor.2 Verify that the voltage to the seat slide motor on the harness side between "BR" and "W/B" is 12v when the power seat's switch is pressed backwards and forwards. Jot down your radio presets and tap the seat slide motor so that the motor will work long enough to give you access to the seat mounting bolts.3 Pull the seat as forward as it will go. Take off the two M10 rear seat mounting bolts and set them aside. Push the seat as far back as it will go. Take off the two M10 front seat mounting bolts. Switch the ignition so that it marks "OFF." Unplug the negative battery cable. Stand by for 4 minutes. Raise the seat assembly to find the harness-to-seat connectors. Disconnect them.4 Take out the entire seat assembly and place it on a dry, clean, flat surface. Position it so you can access the bottom of the seat. Undo the seat bottom's carpet flap and take out the four M8 bolts. Then, take out the top screws from the right hand and left hand side finishers. Unplug the seat sub-harness connector.5 Put both the seat rails back into their rear position and take out the worm gears, motor, flexible wire and gear boxes all at the same time. Take out the flexible wire from the gear boxes using a screwdriver. Verify that the new seat track mounting tab makes contact with the rear stopper and that the threaded shaft facing up is point upwards. 6 Install six new rubber grommets. Place the new worm gears, flexible wire and gear boxes into the frame. Reposition the seat tracks over the seat track mounting tabs. Use your hand to tighten the M6 bolts securing the seat track mounting tabs. Torque the six base plate nuts securing the gear boxes to 64 to 85 inch pounds (7.17 to 9.69 Nm) and the M8 bolts on the seat's front edge to 13 to 17 foot pounds (17.5 to 23.7 Nm).7 Plug the slide motor connector back in and hook the carpet flap's strap. Reinstall the seat assembly and reconnect the electrical connectors and negative battery cable. Torque the mounting bolts to 27 to 36 foot pounds (37 to 49 Nm). Operate the seat to make sure that the problem has been resolved
Sep 29, 2011 | 1993 Toyota Land Cruiser
How do you get to the rear end springs of a 2001 Ford Taurus without taking the whole car apart.
you need to remove the complete strut assembly from the car to replace the springs and as such you will need a spring compressor to compress the spring for removal from the strut assembly.there should be 3 nuts at the top of the strut that mount it to the inner trunk and 2 bolts and nuts that mount it to the spindle assembly at the bottom of the strut.then you can remove the strut from the car.compress the spring remove the upper bearing plate nut and remove the upper bearing plate then remove the spring.install in reverse order and make sure you note how the components were positioned when removing,as you will have to assemble components in the same position as they were when you started.
Jun 08, 2011 | Ford Taurus Cars & Trucks
I just got a new seat belt for OE Vee Dub that was made in Germany. The spool will not turn and am wondering if I need to take the spool assembly apart in order to fix this problem and if it is even...
There is a possibility that it is not fitted properly as all seat belts have a special mechanism that will not release them or pull back if it is not correctly inline, and normally you cannot do the fixing job by yourself as the new types have electrics in them and all sort of springs and pulleys, best option is to get it fitted and tested by a garage.
Oct 25, 2010 | Volkswagen Camper Cars & Trucks
Need to replace stop light
Tail Lamp Assembly Removal & Installation To Remove:
  1. Remove the tail lamp assembly retaining screws from the body.
  2. Release the locking pins by pulling the assembly directly rearward.
  3. Disconnect the tail lamp assembly connector.
  4. Remove the tail lamp circuit board from the assembly.
To Install:
  1. Install the tail lamp circuit board into the assembly.
  2. Connect the tail lamp assembly connector.
  3. Push the assembly directly forward into the opening to engage the locking pins.
  4. Install the tail lamp assembly retaining screws into the body. Torque the screws to 17 in-lb (1.9 Nm).
High Mount Stop Lamp Removal & Installation To Remove:
CAUTION
Raising the liftgate with the liftgate window open can damage the high mount stop lamp, liftgate hinges, and the liftgate window.
  1. Raise the liftgate.
  2. Lower the rear of the headliner by removing the rear headliner pins.
  3. Disconnect the high mount stop lamp connector.
  4. Remove the high mount stop lamp grommet from the body.
  5. Lower the liftgate.
  6. Open the liftgate window.
  7. Remove the high mount stop lamp retaining screws from the liftgate window molding.
  8. Remove the high mount stop lamp from the vehicle.
To Install:
  1. Place the high mount stop lamp onto the vehicle.
  2. Install the high mount stop lamp retaining screws into the liftgate window molding. Torque the screws to 22 in-lb (2.5 Nm).
  3. Close the liftgate window.
  4. Lift the liftgate.
  5. Install the high mount stop lamp grommet into the body.
  6. Connect the high mount stop lamp connector.
  7. Install the rear of the headliner by inserting the retaining pins.
Oct 18, 2010 | 2004 GMC Envoy
Do i have to remove the back seat to take rear struts off
Answer
REMOVAL - SHOCK ASSEMBLY
NOTE: Access for the nuts attaching the rear shock assembly upper mount to the vehicle is through the inside of the trunk.
Roll back carpeting on top of the rear shock tower to access shock mounting nuts.
Remove plastic cover from the top of the shock assembly.
Remove 2 nuts attaching the shock assembly upper mount/spring seat to the shock tower.
Raise vehicle on jackstands or centered on a frame contact type hoist. (Refer to LUBRICATION & MAINTENANCE/HOISTING - STANDARD PROCEDURE)
Remove the rear wheel and tire assembly from the vehicle.
Remove two fasteners holding the splash shield to the shock assembly upper mount.
Remove bolt attaching shock absorber to rear knuckle (Shock Absorber Attachment To Knuckle).
Remove the shock absorber from the rear knuckle first when removing the shock absorber from vehicle by pushing down on the rear suspension.
Move shock assembly downward and tilt top of shock outward, then remove shock assembly from vehicle through top of wheel opening
Nov 23, 2009 | 2002 Dodge Stratus
Gearbox
Assemble as follows:
Clutch assembly on top of gear box, followed by the retainer clip and then the washer. For future reference, searspartsdirect.com has helpful illustrations to assist you in component identification and assembly. Just type in your model number and follow the links on the next page. I hope this helps you.
Jun 12, 2008 | Whirlpool LSR7333 Top Load Washer
Dimplex DS5598
Disconnect power to unit before attempting to repair unit.
1.With the front door closed,gently place the stove, door side up on a flat surface.
2.Remove the heater assembly retaining screws located on the bottom of the stove with a screwdriver.
3.Lower the heater assembly off of the bottom of the stove being careful not to damage any of the wiring.
4.Disconnect the wiring clips and connections noting their original location.
5.Remove the heater assembly mounting screw and remove the heater assembly.
6.Properly orienate the new heater assembly and connect all of the wiring clips and connections.
7.Reassemble in the reverse order as above.
Pleas note, if you are not comfortable to do this please call your local dealer on Dimplex or go to the Dimplex website and they can locate someone for you.
Apr 06, 2008 | Dimplex DS5598 Mid-Size Heater
Huffy Pro Thunder Boys 16-Inch BMX Bike Logo
299 people viewed this question
Top Huffy Cycling Experts
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
