Question about Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
Posted by cmoney745 on
  • Sharp Master
  • 6,164 Answers
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Posted on Dec 15, 2010
Sharp Aquos 30" monitor only
The monitor will not work without the AVC box.
Do you still have the monitor? Is it in good condition? Would you be willing to sell it? If so, please email me at [email protected]
Apr 17, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Hi my sharp aquos lc-30hv4u keep's blowing the main ac fuse 3.15amp 250v. i looked at the main power board it looks good. is there something i can look for? thanks for any help.
On the power board look at the electrolytic capacitors . The top of them should be flat. If they are domed on top or have leaked out the bottom then they need to be replaced.
Mar 13, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I have a Samsung P2771hd monitor. I have green and black cords (for sound and microphone) coming from the computer. I bought a cable that has the black plug from the pc that splits to the red and white...
The Red (right channel) nand White (left channel) RCA plug to miniphone jack is made for audio amplifier with RCA input jacks. The monitor should have Green audio input mini stereo phone jack for the audio input from the PC audio line out (Green mini phone jack).
You will need the shielded audio cable with mini stereo phone plug at both end for the audio hook up.
Dec 21, 2010 | Samsung P2270HD 22" LCD Monitor
I have a Sharp Aquos LC-26D40U. I have connected my sat box via hdmi and I get nothing. I have tried several hdmi cables and hdmi equipment nothing works.Its looking like I need to replace the HDMI signal...
Hi:
You can try partstore.com or a cheaper solution is to go to ebay and input your model number for a search, there you might find refurbished boards and new boards that shops are selling for sets that had broken PDP panels etc.. (BAD LCD SCREENS)
Dec 02, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Oct 15, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Sharp Aquos LC-32GH5 and MacBook problem, HELP! I've recently bought a 32" Aquos and want to use it with my MacBook as a secondary monitor and screen for movies, etc... I bought all...
it sound like you did the right thing . The problem is the mac output for sound is bad or the TV input sound is bad.
try input a mp3 radio to the TV verify TV is working.
put an earphone to the mac to verify the mac out sound is working .
if both are working just tool around a little and you will get it. good luck
Aug 18, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Red is missing
Have you checked the voltages for the red video output from the video processor? Also check and see if the LCD array responds to signal input directly.
Sep 21, 2007 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp Aquos LC-30HV4U 30 in. LCD HDTV Logo
657 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
