0156 works for me 3/1/2015
Turn on your Toshiba TV.
Press the TV button on your Sky remote control.
Hold the Select and RED buttons for several seconds until the LED blinks twice then release.
Press the TV button again
Enter the 4 digit brand code: 0156 - the LED will blink twice
Point the remote at the TV and press the Stand by button.
If the television goes into Stand By press the SELECT button to store this code.
If the TV does not go in to Stand by mode, press the TV button and repeat from step 6
SOURCE: LG 42PG6010 sky code
this might work
0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
SOURCE: code for sky+remote control for lg tv 50pc56
1293 worked for me. But here are some more
0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318,
0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367. We also have some older codes;
206, 037, 060, 065, 080, 137, 191, 244, 245, 275, 318, 389, 391, 398, 405, 459, 502.
The codes are stored in a database of the Sky remote. If the above codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes. Best regards, LG Electronics.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
SOURCE: Struggling with Sky remote codes for new Samsung TV LE32A457
0060, 065, 584, 037, 245, 476, 398, 516, 292, 318,037
these are samsung codes for sky remote
good luck
SOURCE: hi there i need code for sky remote to pair up to
if you look inside the battery compartment there should be a revision number for the remote.
for a LE40b652 use -
Rev 4 or 6 Remote - 0646 or 0502 or 0615
Rev 8 Remote - 0646 or 0840 or 1340
SOURCE: sky remote code for vistron tv ut3219b
I've tried all the code know to man, it just doesn't work. Ebuyer buy these TV's in they are made from a few different manufacturers components and none of their codes work. If anyone else finds the code let me know and i'll eat my own head.
