Samsung Propel A767 Cell Phone Logo
Posted on Dec 14, 2010
A week ago, my Samsung Propel screen started changing colors. Red, blue, yellow, green. It was stuck on a blueish tint for a few days and now it is stuck on a white screen. I still hear the sounds of the phone but cannot see anything.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
449
Points
Hi but my phone has just done the same thing today what did you do with yours?
  • blwdbabie189 Mar 29, 2011
    I FINALLY FIGURED IT OUT!! my phone was doing the same thing, it would filter different colors on and off and then eventually it just became a completely working phone except with only a white screen. I just disassembled everything and found the tiniest tear in the black strip that connects the screen to the phone. I don't think there is a fix for this, unfortunately, other than buying another phone and switch the screen. You can probably get one on Ebay.com for a few bucks. I can't believe I sold my old broken one just a few months ago! Should've kept it for the parts..
    ANYWAY, I hope that helped.
    ---> small tear in the connecting strip is my diagnosis.
Mits. rear projection tv ws65905 picture has blue color tint
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
3helpful
3answers
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
Color changed suddenly, no red, just green/yellow/blue
Sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel.
1helpful
Yellow/green tint moving toward the center of the screen
Bad news the blue uv cut filter is discoloring its in the optical engine.
You are one of the many sony tvs that have this problem.
GOOD NEWS - sony will pay for yours
http://esupport.sony.com/US/perl/news-item.pl?news_id=115&mdl=KDFE42A10
Thanks
scott
Shows blueish color when i play dvd
hi..the reason to this problem is you might not
have plugged the cable properly.
check it out..
thank u..
rate me..
5helpful
2answers
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
2helpful
2answers
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
