Question about Cooper Industries Cooper Wiring 2504W Fluorescent Lampholder, Plunger, Push Wire Cap Screw Sw
How do you change a 2 wire ballast to a ballast with a black and white wire,2 reds and two blues.I have a 2 tube 18 inch fluorescent lamp with 2 ballasts in it.Each ballast has 2 wires coming out of it.They gave me a replacement one with a black and white wire,2 reds and 2 blue wires and told me it would work but I am not sure how to rewire it.Any help would be appreciated.
  • 388 Answers
Dear sir
first do not confuse by the colour of ballast wire, now see black and white wire who is coming from the ballast and find out after that you have to remove it from the joint . and other new ballast replace here and it's wire connect here with that point where you has remove wire black and white wire first from here. and try to fix fluorescent light here and after that try to switch on electric supply for testing. i hope after that it will work.
thank you
hope answer the question
please vote!
Posted on Dec 14, 2010
Anonymous
SOURCE:
I want t replace a mb2x40/120 rs ballast with a 120 277v electronic ballast how do i wire it
Rule #1: TURN OFF THE POWER AT THE BREAKER PANEL.
A fluorescent light ballast is a transformer that outputs a higher voltage than the input (120 volts). The electrocution hazard is very real.
Practically all ballasts have a drawing printed on the label. As a master electrician I still need the drawing to install them properly. Electronic ballasts should have a black and white wire for input voltage. The output to the lamps will be some combination of: red, yellow, blue.
The new ballast must also be matched to the type of lamp. Old fluorescent lamps were T12 (refers to the diameter). New lamps are T8 and produce more lumens with lower amperage.
Sep 27, 2014 | Electrical Supplies
How do you disconnect ballast wires from Lithonia Lighting Fluorescent fixture?
The feeder or supply power wires (black and white) are the primary of the ballast or transformer, if we are talking about house wiring. The secondary side of the ballast (usually red, blue and yellow wires) supplies from 600 to 800 volts to the lamps. This makes this job very dangerous. Are you sure you want to do this job? Buy a repacement fluorescent fixture, the cost of the ballast will be about the same as the cost of the fixture.
Aug 29, 2014 | Home
Fixture not working after bulb change
"CFLs" Compact Fluorescent Bulbs (with built in ballast) must be labeled as dimmable to be used on a dimmer circuit.
Traditional fluorescent fixtures must have a dimmable ballast installed inside and can be used with standard fluorescent lamps.
Fluorescent lamps must be sized to match the ballast. CFL's are matched at the factory, but others are not. Older fluorescent lamp fixtures have a ballast inside. A type rating is to operate (2) 48 inch / 40 watt lamps. Newer fluorescent lamps are rated for 32 watts, and these will not work - or will have a greatly reduced life.
If you installed CFL's, the first thing I would do is install regular incandescent lamps and see if it works as expected. If not, something else is wrong - otherwise - make sure you've got the right lamps in the fixture.
Mar 17, 2014 | Electrical Supplies
Testing photo cell
These devices typically require a minute or two to change state from ON to OFF when the the threshold of light and darkness is reached. Place black electrical tape over the sensor and allow a minute for it to turn the light on. Make sure that no light shines into the sensor or that the sensor can not see light in the night time.
Lastly, double check instructions and wiring. White should be connected to BOTH the neutral incoming power AND the light fixture's white wire(s). Most times, black is 120V source, and red is the switched 120V out to the fixture.
If it isn't working, make sure the lamps are good. This photocell is suitable for use with compact fluorescent lamps, fluorescent lamps and other fixtures that use ballasts and transformers as long as they do not require more than 840 VA.
Dec 29, 2012 | Carlon Home Products Wired Photo Cell Post...
How do i connect a ballast
Hello. Not sure what ballast you are looking for but I am guessing a Fluorescent light replacement ballast. Normally in a 2 tune balleast there are a BLACK and WHITE, These are Hot and Common. 2 Yellows go to the one end of the tubes. The 2 Blue wires go to the end of one of the tubes and the 2 red wires go the end of the other tube
Black to Black, White to White. 2 yellow to Tube 1 and 2 yellow to Tube 2. 2 Blue to Tube 1 and 2 Red to Tube 2.
Hope this helps..
Nov 04, 2012 | Televison & Video
I have a 4 ft 2 lamp flourescent system. I am changing the ballast. The existing wiring has blue / red / yellow / black & white wires. I have a new ballast (yes I confirmed at the store it is the...
The first thiing I suggest is checking the installation instructions (either included with the ballast or on-line) of the ballast you just purchased. Many fluorescent ballasts require that the lamps be wired in series - which I believe is what you had before. One lamp connects between the red & the yellow, the other connects between the yellow & the blue. Other fluorescent ballasts require that the lamps be wired in parallel - which may be what you have now (both lamps connect between the red & the blue). The installation instruction sheets should designate the appropriate wiring configuration.
That being said, just double-check one thing: Make sure the new ballast is rated for 2-lamps. Ballasts rated for 1-lamp will only include the red & the blue (no yellow). So I know you sad you already checked with the destributor, but double-check that one point.
May 15, 2011 | Electrical Supplies
I have a 3 bulb flourescent light that had two magnetic ballasts and I want to replace it with a T-8. What is baffling me is that from one set of sockets on one side there are 6 wires, 4 blue and 2 red and...
  • 1 Turn off the circuit breaker that's delivering the power to the light fixture.
  • 2 Test the feed wires with a touch-type voltage tester before you touch them. Press the button on the tester and touch the tip of it to each wire to make sure the circuit is dead. If the tester beeps or lights up then the circuit is still live. Try additional breakers until you find the correct one.
  • 3 Strip about 3/4 inch of insulation from the ends of each wire coming from the ballast if they aren't already prepped for wiring. Use the smallest setting on the wire stripper to prevent snapping the wires when you strip them.
  • 4 Take the single red wire from the ballast and insert its tip into one of the two pressure-slots on top of one of the sockets on the same side of the fixture that the red wire is facing.
  • 5 Take a 6-inch length of similar red wire and strip 3/4 inch of insulation at each end, then insert one end into the second slot on the socket that already has the red ballast wire attached and insert the other end into the other socket on that side.
  • 6 Insert the tip of one of the blue wires into the slot on one of the sockets on the other side of the fixture.
  • 7 Insert the tip of the second blue wire into the slot on the other socket on that side of the fixture.
  • 8 Connect the white wire from the feed circuit to the white wire on the ballast and connect the black wire from the feed circuit to the black wire on the ballast. Make sure the wire connectors are on tight and wrap electrical tape around the connections.
  • 9 Put the fixture back together and install the fluorescent tubes as per the manufacturer's instructions. Turn the circuit breaker back on.
  • Mar 25, 2011 | Kitchen Ranges
    How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
    Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
    Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
    Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
    1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
    CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
    1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
    • Cruise Control Information • Stereo Information • View all Jeep Vehicles
    Dec 18, 2010 | 1996 Jeep Grand Cherokee
    LIGHTING QUESTION: I have a GE Pro line T8 Ballast w/ (8) wires (2) Blue, (2) Red, (2) yellow plus Black & White. I know what the Black & White are for and are not connected to the lamps. Can you...
    Try this link-- for a wiring diagram--- let us know if this helps-- Mack
    http://www.replicasuper.com/wp-content/uploads/2016/01/T12-Ballast-Wiring-Diagram-Here-Is-An-Example-Of-A-Circuit-That-You-Can-Make-The-Guidelines-For-Making.jpg
    Oct 27, 2017 | Vacuums
    Cooper Industries Cooper Wiring 2504W Fluorescent Lampholder, Plunger, Push Wire Cap Screw Sw Logo
    784 people viewed this question
    Top Cooper Industries Electrical Supplies Experts
    Gene Haynes
    Marvin
    Marvin
    Are you a Cooper Industries Electrical Supply Expert? Answer questions, earn points and help others
