1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
For more help visit cbrtechsolutions
SOURCE: cannot print canon ir2200
toner waste bottle full. Take it out and clean it well particularly around the neck...which is where the sensor is.
SOURCE: canon ir2200 error code is E0602-03
Dear Mohann ,
Its Hard drive related problem .
Solution 1# :
It can be a Sector Problem ,to resolve it just press 1&9 keys at the same time the machine started the HD Diagonose and it repared the sector error without replacing the HDD .
Solution 2# :
try to go in to disc check service mode to clear the sectors ,this
should work if it doesnt you will need to replace the hard drive .
Solution 3# :
Try HD clear & then HD check for every sector in service mode. Then
try to upgrade system software;If nothing works change hard disk
,format & install system software.
i'm sure these solution can solve your problem 100%
Cheerup and Be Happy always
SOURCE: Canon iR2200
press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
