Viore DLP tvs are a low end samsung. Samsung has a problem with a defective DLP chip. Every one of the white or black spots is a stuck mirror in the chip.Viore DLP tvs are a low end samsung. Samsung has a problem with a defective DLP chip. Every one of the white or black spots is a stuck mirror in the chip.
You can't post conmments that contain an email address.
Thats caused by the DLP chip. Unfortunately most Toshiba models will end up having to have both the DLP chip and the formatter board replaced at the same time to fix the issue where as other models only require replacing the DLP chip alone to fix the white dots issue
The screen/s may only be sold as a unit based on the model number posted here its a DLP. Try first to see if even available, a guess would be more than 300 dollars for the parts alone.
these are called dead pixels if your television is under warranty you should replace it with new one cause dead pixels generated new ones until it will fill up your screen completely.
White pixels are STUCK pixels, not dead. Read the warranty beacuse at a certain number of stuck/dead pixels, the tv is repaired for free by the seller if is in warranty period.
Random dots or pixels failing on a DLP TV will be a bad DMD chip. This is a technician replace item only. The chip runs around 160 dollars list price. The part number will depend on which version the set uses and will be determined by the technician.
if you use the local channel the raster is coming out? or try to use the DVD input video then testrun if the raster is there you have defective video driver and need to replace
