Locate the Temperature Control Knob: The temperature control knob is typically located inside the freezer compartment. It allows you to adjust the temperature settings.
Understanding the Knob:
For Top Mount ™ Models: The temperature control knob is usually located in the refrigerator section. At higher altitudes (e.g., 1000 meters above sea level), set the refrigerator temperature control to one-half setting warmer than MID.
For Bottom Mount (BM) Models: Adjust the refrigerator temperature using the bottom knob.
Setting the Temperature:
Turn the knob clockwise (usually towards the "colder" side) to lower the temperature.
Turn the knob counterclockwise (towards the "warmer" side) to raise the temperature.
Adjusting the fridge compartment temperature may cause a small change in the freezer temperature.
Remember to allow some clearance around the freezer for proper ventilation.
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
A flashing red light on a tall freezer indicates that the appliance has detected a temperature alarm, and the temperature inside the freezer has likely dropped below the desired range. A temperature of -6 degrees Celsius is much lower than the recommended temperature for a freezer (-18 degrees Celsius), which can cause frozen food to become damaged or spoiled.
To resolve the issue, you should first check the freezer's manual for troubleshooting tips and recommended actions. In general, you may need to adjust the thermostat to a higher temperature, remove any obstructions to airflow, or defrost the freezer if ice buildup is blocking the evaporator coils. If the issue persists, you should contact a qualified technician to diagnose and repair the freezer.
Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
? 3:50
https://www.youtube.com/watch?v=DFzTGKVo79g
Jun 27, 2010 - Uploaded by GE Appliances
CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
Service engeener always checks the average temperature inside freezer or refrigerator compartment. When you turn on freezer, the compressor starts to circulate gas through the system and the temperature in the freezer is decreasing (go to minus). When inside of the freezer reaches the set temperature the compressor is switched off and temperature will increasing. What will be the difference of inside temperature depends on the type of refrigerator and type of thermostat or sensor and moves to max. 8-9 degrees. With the advent of new "No Frost" refrigerator, this difference was reduced to only a few degrees Celsius, thanks to the fan inside the refrigerator and NTC sensor.
So 29 + 14 = 43; 43/2 = 21.5 which means that your average temperature of -21.5 which is not too much deviation from the set temperature of -18 and I think that is ok.
I understand that you are looking for the temperature control knob on your Frigidaire freezer, model# FFU2064DW. The temperature control is located inside your freezer on upright models, and on the left outside wall on chest models. The temperature is factory preset to provide satisfactory food storage temperatures. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. Hope this is helpful.
It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation.
Normally freezer will go down to below zero degree
Good day, Manufacturers of freezers do not give the option of running the machine much above that temperature. Normal operating temperature for a freezer is about -2 to about 8 above F. Otherwise people could accidentally set the temp too warm and cause a loss of food. Some appliance parts houses carry universal thermostats that could possibly cover the temperature range your looking for, but 30 degrees is far to warm to preserve frozen food safely.
