Usually related to the in-tank check valve. Follow the discharge hose from the pump to the tank. At the tank the hose attaches to a brass valve (or metal valve). This brass fitting is the check valve. It's purpose is to hold air in the tank and not allow the air to load the compressor when motor is trying to start. Easy to test. Use another compressor to pump air into your tank thru the quick disconnect or remove the safety valve and install hose there. Pump in about 75 psi and looks for leaks with soapy water. Remove air inlet hose from check valve and check for air leaks. If leaking, replace with generic valve available at www.grainger.com or order from sears parts. If no leaks then suspect unloader is not working at the pressure switch. If both the unloader and check valve is ok then test capacitor for reading within 95% of rated valve. Good holidays
