Sony NWZ-B103FBLK MP3 Player Logo
Question about Sony NWZ-B103FBLK MP3 Player
It will just show the walkman logo and go off
Posted by tosins73 on
Anonymous
    New Friend:
The problem your device is of software....all u had to do is,...download firmware1.3 software from net and run the software....when the software run...it will ask for the device you want to install the software.insert your walkman it will install the software on it and......wallah it will start running as it was before
Posted on Dec 23, 2010
Mys/e w705 shows the s/e logo when i turn it on but then just goes to a blank dim lit screen
Connect to pc, using sony pc suite, update or restore the firmware on the phone.
7helpful
3answers
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
1helpful
The startup screen stays on and trys to load, but nothing happens. It shows the Walkman logo and their slogan and it's the same screen that shows up when it's starting up, but it's not getting past this...
Try a reset -- on the back of the player is a small hole that the tip of a paper clip will fit into. Press the tip in that hole for a cold start. you will not loose anything on the player.
2answers
When connecting to pc only walkman logo is showing &
there's a range of possible solutions to this problem.Your best bet is to go the sony website and work thru their suggestions -if you get stuck come back here and describe the problem.good luck!
http://www.usersmanualguide.com/sony/mp3_walkman
Only show the Walkman Logo
press and hold "volume -" button while connecting to pc...then it must be detected
7helpful
NWZ-B135 stuck on 'Walkman' logo, but won't go to play mode.
U need to upgrade the firmware,you need to download the firmware from here: http://support.sony-europe.com/dna/downloads/firmware/firmware.aspx?site=odw_en_GB&m=NWZ-B135&f=FRM_NWZ_B13x_f after downloading,run it and then connect the player to system while holding the "volume -" button...it should be detected and the firmware would be restored.
2helpful
My Walkman is going berserk
when that happens you want to get some thing sharp and hit the reset button on the bottom of the Walkman
Starting up
try to on it... by pressing the play button or on button by pressing it for few seconds... else try to format or update..
Top Sony Audio Players & Recorders Experts
Marvin
Marvin
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
