ElectroVoice EVM10DLX 10" Subwoofer for Guitar or PA system Logo
Posted on Dec 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Would putting an EVM10DLX into a set of Yamaha BR-10s be a recommended upgrade? Worth the cost?
Fred Yearian
Level 3:
  • ElectroVoice Master 5,603 Answers
  • Posted on Dec 14, 2010
Fred Yearian
ElectroVoice Master
Level 3:
Answers
5603
Questions
Helped
2248648
Points
16162
It is VERY RARE for such a change to be beneficial. The cabinets and speakers are finely tuned to work together and the originals are usually just as good performers as anything you can replace them with. If you want a subwoofer you need to get a larger cabinet and preferably a larger speaker. A ten inch speaker for subwoofer use would require a closely engineered cabinet. Best to go to a single powered 15 inch subwoofer (one designed as subwoofer) to run alongside your BR-10's.
2answers
How can I Import and export voices from or to Yamaha DGX 640 from my PC running with Windows 10 ?
ask yamaha this, direct to them or read the manual firsts. 2010 made.
lost the manual ? did you?????
any app you run most be from maker yamaha for w10.
Yamaha DGX-640 88-Key Portable Digital Grand Piano with Weight-Graded Hammer Action.all there is , is here
yam
https://usa.yamaha.com/support/updates/index.html?c=digital_pianos&k=640
https://usa.yamaha.com/files/download/other_assets/2/314552/dgx640_en_om_a0.pdf
i guess you talking about what page 15 states.
then page 97 how to do it>?
what it can do is all there song file wise.
it shows w7 max.
but some apps w7 sure can be loaded to w10 or drivers
using windows 10
w7 compatibility mode as MS tells you.
seen here.
windows 10 32bit or 64 I see this too
https://usa.yamaha.com/support/updates/index.html?c=digital_pianos&k=DGX
try these?
2answers
1helpful
Kohler $ Cambell Piano serial number 734309 what does the serial number mean and approximate value and where can I sell this piano
current market flooded with pianos for sale
ebay has many listed
$500 to $1200 max
yours would have to be a grand or fully restored upright to get top dollar
worth what some one will pay you for it
for example serial number 578613.
this one its owner is asking $ 800 or best offer
Apr 17, 2017 • The Music
1helpful
Koehler and Campbell upright piano model 1951 serial 764863...value?
use this link to get more historical information
contact us
http://antiquepianoshop.com/online-museum/kohler-campbell/
only worth what a person would pay you for it
the only way to get top dollar is to have it fully reconditioned back to looking new by .Kohler & Campbell themselves
.internals and outer casing
lots of pianos out there for sale
a basic upright .lucky to get .$800 or less
1951 ..not that much in demand not rare
iron framed and depends on what the condition
Jan 13, 2017 • Music
My yamaha cvp 601 no longer turns on. What could be the possible problem?
strange and annoying
any power surges noticed
could be wall plug lead
or the 240 volt internal power transformer problem
26338855-vgifjk0cmh4fityltrfmb02q-5-0.jpgyamaha-cvp-601-no-longer-turns-could-vgifjk0cmh4fityltrfmb02q-5-2.jpg
1helpful
Can a replacement circuit board for a yamaha silent violin be purchased from yamaha?
there are repairable
all yamaha musical instruments web sites do have authorized service centers listed
sub menu services
link
https://www.yamaha.com/en/
worth contacting amazon also .
they may have a Yamaha repair contact
amazon sell the whole violins .
Amazon com Yamaha SV 130 Silent Violin Navy Blue Musical Instruments
How do i fix a Yamaha P95 that sounds Es with Fs and Bb with Bs across all the octaves?
Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
fix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-0.jpgfix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-1.jpg
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
I have an older keyboard. None of the G or G flat keys are working. Is it worth fixing or just get a new one?
Most likely it is not worth it fixing it. You can probably get a new model with more features for about the same price of fixing this one. Let it go anf upgrade. That is the reality of electronics and technology.
1helpful
5answers
How to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
2answers
Yamaha electone organ no sound-
Check if you may have knocked off the speaker leads OR ones to an expression pedal.
Top ElectroVoice Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an ElectroVoice Music Expert? Answer questions, earn points and help others
