Question about Xerox DocuColor 12 Printer
Hi Dear Can use xerox DC12 with MAC OS without
Hi Dear Can use xerox DC12 with MAC OS without fiery??? Best regards.
Posted by ahmedf791 on
kabir Sk
    New Friend:
Os damage
Posted on Jan 25, 2014
  • Xerox Master
  • 7,733 Answers
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Posted on Dec 14, 2010
Patch installation sequence for the Fiery X12 with DC12. Hi, I had a problem with Rip and I installed the 1.5 system, but the system can not find the DC12, it says "Error network controller." I have...
You need install patch "1-56CTS.ps". Try to find it via web.
Also install Fiery Downloader app. Go to File->Download and choose file "1-56CTS.ps". Then reboot a fiery and problem must go away.
Oct 29, 2013 | Xerox DocuColor 12 Printer
Hi I buy the xerox docucolour 12 printer please please i need to install my xp computer and vista computer how i install driver and configire if you have any video instraction file pls share me tks a...
hi friends,
this is aditya (+91)9836593201.
at 1st you go to front of your fiery & xerox machine,an on it.
when dc12 will show redy to copy and fiery show idel.you go to start butten on your xp os.
printer and fax >
add printer>
next>
locale with automatic >
(sarching...) >
next >
creat a naw port->
standerd TCP/IP >
next >
type your fiery IP address on the box of printer name >
next> next> next>
finish>
have disk>
brroush>
(select location of your printer driver)>
open>
ok>
next> next> next>
finish.
your printer driver have to install.
May 21, 2011 | Xerox DocuColor 12 Printer
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
DC12 Fiery EX12 network problem with vista
Remember some times Windows Vista disable the spool service, only you have to enanble it and ready..
Sep 30, 2009 | Xerox DocuColor 12 Printer
Xerox DCCS50 to DC12, change Cobra with X12 fiery
at the end of setting up network settings it should ask if you want to save settings, click yes then its enabled. i have never had a fiery that doesnt hold its settings so its probably something you arent pressing.
there is an issue with one of the mac OS's that it just doesnt like the old fiery rips and you will never be able to print, but i'm not that clued up on the mac side and cant remember, sorry.
from your add printer section it should automatically see the x12 and give you the options of a hold,print and direct queue. I f you havent got a pc then the only queues that is useful to you is direct. Print holds the job on the hard drive and will eventually fill the server
Jun 19, 2009 | Xerox DocuColor 12 Printer
Graininess on xerox dc12 print s
hi i think u took print in low resulution photo. pls check ur phot resulution.
Nov 21, 2008 | Xerox DocuColor 12 Printer
Solution for fiery card in dc12 fieries
hi may i know the exact problem in ur fiery card?
Sep 24, 2008 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 color copier language problem
Hi, there is no way to change language on Touch screen without calling Service. Best regards.
Dec 27, 2007 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
513 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
