Question about Kenneth Cole Reaction KC1345 Watch
I bought a new kenneth cole KC1345 watch, I have set up the time and date, however although the second hand seems to be running, the hour and minute hand is not running. The second hand is running with no time change. The Chronograph second hand and minute hand are also not running.
Posted by siddharth108 on
Anonymous
    New Friend:
  • 93 Answers
Read carefully the manual, you might have push the stop botton. chronograph watches are very tricky to use.
Posted on Dec 14, 2010
How do I set the time and date on Kenneth Cole women digital watch with 1 knob. Model KC2698. Thank you
most watches with one knob have a duel action on that knob
the first click is the date section , pull it out a bit further to a second click and that is the hands movement
when set to right date and time push the knob all the way back in
Mar 11, 2016 | Kenneth Cole Watches
I have a watch numbers on the back are s301-07 kc1345,, i need a band , mine broke
mcdevito75 here, Check on ebay, biy you"ll need the band size in MM. also any watch repair shop could help out, look for the small repair shops to save some money.
Jun 14, 2010 | Kenneth Cole Goldtone Chronograph Date...
I recently bought a Kenneth Cole KC 3790 as a gift and I am tying to set the date...the date is presently Saturday 27th February and I am having difficulty getting to the 27th day of February on the...
Pull out crown to the time setting position (second click) and set time to 5.30 pm or am. Push crown back completely. Pull out crown to the date setting position (first click) and set it to 26th, then pull out crown further out to the time setting position (second click) and adjust watch hands forwards until the date changes to 27th. Date is changing at midnight, so, continue to adjust hands forward to the right time. Rate me, plz.
Feb 27, 2010 | Watches
How to set date in kenneth cole watches kc1345
Good day Sir, The winder has two click points ...
1.pull out to the 1st click point to set the date.
2.Pull out to the 2nd click point to set the time.
have a nice day.
Dec 02, 2009 | Kenneth Cole Reaction KC1345 Watch
Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Oct 30, 2008 | Kenneth Cole RK5034 REACTION
Kenneth cole reaction
Jul 16, 2008 | Kenneth Cole RK5034 REACTION
Kenneth Cole Reaction KC1345 Watch Logo
379 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
