Nokia 6600 Logo
Anonymous Posted on Dec 14, 2010
Help me plzz!!!My Nokia 6600 Phone dropped by me.I just switched on it but a white display appears for a second and offed.Any answers pls!!
Anonymous
Level 2:
  • Expert 112 Answers
  • Posted on Dec 14, 2010
Anonymous
Expert
Level 2:
Answers
112
Questions
0
Helped
38244
Points
419
Change your Display .....
After switching on nokia6600 the screen shows while screen?pls help to solve the problem
Even if the display is white and your phone is working good you need to check the display connector,LCD and the related components like display IC.But if you can remove the case at least you yourself check the display connector sometimes this problem occur due to dissemble of the connector Or contact mobile repairing shop for service.Good luck Thanks for visiting fixya
Oct 06, 2011 • Nokia 6600
5helpful
3answers
The n6600 is turning on properly but after a few seconds it turns white screen only and keypad lights turn off and turns on when power button is pressed.,.,how can i repair it?please help me.,.,
The Problem is with your 6600 Software just Flash it (renew mobile software)
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 16, 2011 • Nokia 6600
Nokia 6600 keypad malfunction
TRY THE MANUAL FOUR BUTTON PRESS FORMAT THAT IS SWITCH OFF YOUR FONE, THEN PRESS DOWN *3 THE GREEN BUTTON AND SWITCH ALTOGETHER AT ONCE AND HOLD DOWN TILL SCREEN DISPLAY FORMATTING
Aug 24, 2009 • Nokia 6600
Nokia 6600 restarts often and completely switches off
try to format your fone mates...
type *#7370# then enter your security code..
backup 1st ur files... hope to help...
Apr 26, 2009 • Nokia 6600
1helpful
Nokia 6600 is automatically switch off
Your phone have a minor problem. You can try to solve to fomat it.Your formt number is *#7370# or*#7303#.
Jan 31, 2009 • Nokia 6600
My nokia 6600 is sending bluetooth messages on it`s own
hi its a very common problem with 6600. u should flash ur mobile from a certified mechenic.OR u must try this method: first switch off ur mobile and switch on ur set while pressing (star key),(dial key or green key)and(number 3 key) till formating screen appear.after appearing formating screen leave the button and let format ur handset.
plzz rate me
Dec 22, 2008 • Nokia 6600
2answers
Not charging for nokia 1100
good evening ! the problem of your phone is the resistor 100 try to chagne that , that`s located at the mother bord! R100 GOOD LUCK ....
Sep 08, 2008 • Nokia 6600
1helpful
2answers
Problem with display of Nokia 6600 mobile
my nokia6600 occurs same problem
when i switch off and then switch on the phone then display comes for the time i am using the phone. As i left the phone for sometime without pressing any key it again goes to that white screen mode..but phone is functioning .plz help me to rectify the problem.....
Jul 14, 2008 • Nokia 6600
1helpful
APPLICATION CLOSE...
There might be a problem either with the program you are using or with nokia 6600 .if you are using facing problem with program try to reinstall that file,but if you think that your mobile is having problem than you can format your mobile or flash your mobile .When you flash your mobile ,it will become new as you you purchased means factory settings....
A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia” screen (may flash “Nokia” 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive. WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
If this answers your question please rate this as fixed.
If you need more help just add a comment and I'll be glad to help you further... Thanks
dilipbagdi - [email protected]
May 11, 2008 • Nokia 6600
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
