Question about Sony KV-35S42 35" TV
Sony kv 35s42 sound but black screen and constantly blinking stand by/timer red light
matt martin
  • Sony Master
  • 1,258 Answers
Your vertical IC will need resoldering. If you can take this board out and inspect the pins under the vertical IC, you will see rings around the IC. This is a common problem for you model of TV. Hope this helps...show a few hands of support.
Posted on Dec 14, 2010
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Sony kv-35s42 35" tv picture blinks off and on
my best advice would be to check power supply for faults, bad capcitors etc to r/o the possiabilies of a power failure.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | Sony KV-35S42 35" TV
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Sony kv-35s42 no picture, good sound timer light flashing
Usually, the CRT is bad......re-juvenation is a temporary fix at best........try adjusting screen control on CRT socket module.
Only other possibility is solder pins of vertical output IC.
Mar 20, 2008 | Sony KV-35S42 35" TV
Timer light blinking
POWER SUPPLY PROBLEM.YOU MUST HAVE SOMEONE REPLACE TWO TRANSISTORS,VARISTOR,FUSIBLE RESISTOR,4 CAPACITORS & HORIZONTAL OUTPUT TRANSISTOR & RESOLDER PINS ON HORIZONTAL DRIVER TRANSFORMER.GOOD LUCK.4TUNE
Dec 05, 2007 | Sony KV-35S42 35" TV
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KV-35S42 35" TV Logo
245 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
