Tasco ProPoint Red Dot Matte Red/Green Dot w/Mount Logo
Posted on Dec 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a Tasco PDP3 redpoint on a 12 guage shotgun. It will group good for 3 shots then wonder off. I've found it to be loose somewhere on every occasion but the last one. My last shot hit the bullseye of the target below the one I was aiming at. I've had some great 3 shot groups but the fourth shot will find itself somewhere completely off the target. At this point I'm wondering if its the Tasco and since its new in October, wondering if it has a warrantee. I purchased it installed by a local gunsmith. My last optiion is to take it off and loctite everything. If that doesn't fix it, guess its time to return it somewhere. What do you think.
Anonymous
Level 3:
  • Master 593 Answers
  • Posted on Apr 02, 2011
Anonymous
Master
Level 3:
Answers
593
Questions
0
Helped
175434
Points
1850
This does sound like it needs a bit of Loctite. But, You need to check this first, Is the scope being put in a bind due to heat from shooting. So, shoot for your group but wait say 7 to 8 minutes in between each shot. If in this case the gun stays on target every time, she is just getting hot and the heat is causing expansion in the mount / receiver area. If she jumps around during you timed shooting, then Loctite her in place, and Retry. If your sighting in slugs for deer hunting, your shots will always be from a cold gun, she needs to be on target cold not hot.
Hi just wondering how u caliberate a esspresso shot on a La Cimbali M23 machine. all heads only run for half of a second.
* You will need to program dosing on each group head.
* I'm surprised I did not record and upload a programing video *sigh*
Oh well, somebody did it already:(check at 3:57 on the following vid)
https://www.youtube.com/watch?v=0-3SbS-PU4Y
* Set up each shot with a filled portafilter (for the appropriate dose setting. Single for single, double for double, etc.)
* Press and hold "Stop" button till it light (and/or beeps). Release stop button
* press and HOLD the appropriate dose button (within 5 seconds or it cancels out)
* Watch the coffee dose as it pours out into cup or a shot glass (for accuracy)
* Release the dose button just before it hits the desired amount. You may have to do this several times to practice.
* Continue with setting the dose on the other settings (long, double, etc.)
* Note; you can set the "least used group" as in a 3 or 4 group head machine with specialty doses. Like a triple if you have the proper portafilter for this shot. Or an "American" long shot (though I don't recommend running 6-8 oz of water through a single coffee dose. Though I have found some shops using drip coffee through a triple basket and very long dose to fill mugs. They didn't want to get a regular 12 cup brewer.)
* There are other dosing tricks like copy over to other groups. But I've found that setting each group and dose is good practice. (and I have to do it several times a day as a Espresso Tech.)
Aloha, ukeboy57
I have an old side by side stevens 12 guage shot gun. it was my grand fathers.# h43559 what year is it.
According to this website (http://www.gundigest.com/gun-collecting-firearm-collecting/sqa-stevens-letter-prefix-serial-numbers) it sounds like it would be between 1913 and 1939.
Dec 06, 2014 • Cycling
1helpful
I bought an Iver Johnson single barrel 12 guage shot gun. Can anyone tell me about this gun?
It was built on the 1890 Hopkins and Allen patent and is very similar to several dozens of inexpensive single shot shotguns.
Dec 02, 2014 • Optics
What battery goes in the tasco propoint
Depends on the model:
Model PDP2....... (1) CR2032
Model PDP3........(2) CR2032
Model PDP3CMP..(2) DL1/3N or 2L76
Model PDTS1 32..(1) CR2032
2helpful
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
4helpful
12 gauge shotgun shell converted to metric (ex. 12 gauge + 20mm)
A ordinary 2 3/4 inch 12 guage shell equates to a European 70 mm. a 3 inch Magnum is a 76 mm.
Goof Luck.
1helpful
Simmons Prohunter Model 517710 won't shoot a group
You SHOULD send it back. There is something loose inside the scope. Even the worst Simmons scope will get you to 2"-3" group. Also, when you replace it, you might want to consider their (or Nikons) shotgun scopes. They are built to with stand the power of the higher centerfire calibers and magnum shotgun shells.
Top Tasco Optics Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Tasco Optic Expert? Answer questions, earn points and help others
