Kodak EasyShare C613 Digital Camera Logo
Posted on Dec 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All my pictures ae either blurry or the lgithing wil be bad except when i take pictures where there's low lighting. whats th problem and how can i fix it?
Anonymous
Level 2:
  • Expert 234 Answers
  • Posted on Dec 14, 2010
Anonymous
Expert
Level 2:
Answers
234
Questions
Helped
92811
Points
769
Try disabling the flash. Sometimes when taking pictures indoors the flash actually blinds the camera.
2answers
Is there any way I can clear up a blurry picture on this camera once the pic is already taken?
On TV shows, they can take a blurry picture and enhance it to crystal clarity. In real life, however, those kinds of miracles aren't possible. In a photo editing program like Photoshop Elements, you can bring up the sharpness a little but you eventually reach a point where the picture no longer looks like a normal picture. The slogan is "garbage in...garbage out"...meaning you can only do so much to what you have to work with.
2helpful
Blurry picture
Try adjusting the focus ring around the lens. Poor quality try adjusting room lighting or you may need to upgrade to a better webcam.
Picture is blurry
this is a problem wit your stk392-110 convergence IC's - One has gone bad and the both should be replaced. Also, check the large resistors near the convergence IC's - it sounds like one of them may have burned up..
Pictures are blurry
this is a symbol for a low light condition. Either increase the light by opening curtains using in-direct light or just use a flash.
6helpful
QuickCam Express, blurry, snowy picture...sometimes the picture is totally shaded red
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens.
This will allow you to focus the camera image on objects at different distances.
Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video.
Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed.
Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds.
If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter.
For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher.
To change the color palette please perform the following steps:
Click on "Start," "Settings," and "Control Panel."
Double-click on the Display icon.
Click on the tab labeled Settings.
In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost."
If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software.
To do this:
Open the QuickCam software.
At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
Choose "Advanced Camera Settings".
Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
Click OK when your are done.
Last, make sure that you ae using the latest drivers.
You can upodate them from here.
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
Red light continually flashes, and won't take picture
I have seen this problem on the ex-s880 casio camera a few times sometimes you can go into the setup menu and reset the camera to default and that some times fixes it. it that does not work I have had to replace the flash circuit on the camera because the large compasitor is out and needs tobe replaces most likely this is your problem because of the flashing LED. Hope this helps its a great camera also you might want to check with casio because this should be covered under warrenty. If the camera was not dropped.
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Blurry or dark pictures in low light
Low light= slow shutter speed = camera shake
Use a tripod
Weird tint and very blurry images
Canon wil replace the CCD sensor under warranty.
It wont take a photo on regular flash
Sounds like your batteries are stuffed, or not of sufficent ma capacity, should be alkline or rechargeable of at least 2500ma
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
