Question about Sony CPD Computers & Internet
Sony CPD 200SX 17" CRT Monitor: Upon resuimng
richie46
    Top Expert:
  • Sony Master
  • 12,962 Answers
Monitor has gone to monitor heaven. time to do some shopping since repair not cost effective.
Posted on Apr 04, 2017
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: white screen covers desktop
Ah A simple one. simply unplug the power adaptor and take itno a repair place or radio shack and ask them to measure the output to see if theres 12 volts DC on the plug?? Good Luck
Posted on Jun 14, 2006
Anonymous
  • 624 Answers
SOURCE: Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Posted on Mar 16, 2007
Anonymous
  • 624 Answers
SOURCE: Sony SDM-HS74P/S 17 Monitor won't stay on the right picture.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Anonymous
  • 624 Answers
SOURCE: How to replace Sony monitor case
I couldn?t find disassembly instructions for your CRT; however, I can give you some safety warnings and some general hints. If no one else posts at mine will either discourage you OR give you enough to start. First off CRTs are dangerous, taking one apart without the proper training and precautions can kill or severely injure you. If you don?t already have the training and experience discharging the stored energy in the monitor you should not attempt it even if you have ?instructions?. If you decided to continue on then there are typically four screws holding the back of the monitor case to the front panel. On some higher end Sony?s they are covered with a plastic cover that you can easily pry off with a screwdriver. Once you have them out then the back cover can be removed, exposing the tube and remainder of the electronics. Again a warning, unless you know what you are doing you run the risk of severe electric shock and should not proceed. Usually there are a series of screws that attach the chassis to the front panel, remove them, the panel electronic connections and the disassembly should be done.
Posted on Jul 19, 2007
Anonymous
  • 709 Answers
SOURCE: Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Posted on Oct 10, 2007
Gateway 2000 monitor screen Vivitron 17 : problem with partial screen
im doing catch up on gateway posts. just 1 day here.
Gateway 2000 Vivitron 17
omg a CRT really?
Gateway2000 Vivitron CRT Monitor 17" CPD-GF200 only google finds manuals on Monitors 2 decades old
nobody fixes CRTs now, and are dangerous with 17,000 volts inside
that can linger. ok>?
time to upgrade no? buy a used LCD LED 2010 or newer flat screen monitor and forget you saw, WAR GAMES and WOPPER
Feb 21, 2018 | Gateway Computers & Internet
I need Driver for WIN 7
There doesn't seem to be any drivers supporting (well, specifying they support win7) but you can try this one. It's the only one out there. http://download.cnet.com/SONY-CPD-E220-E220E/3000-2108_4-169549.html
Good luck.
Dec 14, 2010 | Sony CPD E220 17" CRT Monitor
Monitor not working
Try another monitor on your computer. If you still get a blank screen then its an issue with the computer not having any video coming out of the video card. If you hook up another monitor and you get video then its an issue with the original monitor.
Also try the original monitor on another computer and see if video comes up. If you still don't get video, that would mean the monitor is bad for sure since you would have tried it on two different computers.
May 01, 2010 | Sony CPD E220 17" CRT Monitor
CRT EV730 Monitor Just went out won't power won't do any thing
Check the color of the pluggie that goes into the back of your monitor, it is most likely either blue or white. Find a friend who has the same color plug and borrow their monitor for a few minutes. If theirs works; your monitor has **** out. If theirs does not work then your video card (on-board or add-on card) has **** out and you'll have to have a new card added to your system.
Jun 22, 2009 | AOC CT720G 17" CRT Monitor
Monitor HZ problem
try booting in safe mode and reducing the resolution and the refresh rate to a value which the monitor can handle
Nov 08, 2008 | Sony CPD G200 (White) 17" CRT Monitor
Problems with the monitor's brightness...
1 it is due to low voltage on crt pins. 2 if it is ok check video section 3 crt might be weak if monitor is old.
Sep 09, 2007 | Sony CPD E100 15" CRT Monitor
Monitor
This is a duplicate post, click on the following link to go to the active posting: http://www.fixya.com/support/t139319-monitor
Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
Monitor
Are you sure this is a monitor problem? I have a user with a Mac that occasionally has the same symptoms you describe. For me I generally have to shut the computer down and physically unplug the power cord from the computer (not monitor), reattach it and restart. Let us know if that works for you.
Sony e230 display cable replacement
You will get similar cable in the component market. Just pull out the cable after removing back cover of the monitor, and fix the new one.
Nov 23, 2006 | Sony CPD E230 17" CRT Monitor
Computers & Internet Logo
Top Sony Computers & Internet Experts
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
