Question about HP Compaq Presario SR1538X (PX799AA) PC Desktop
My compaq started but it goes off rightway with a message sying you PC are going off to preven damages. what can i do?
Posted by herediano on
  • Rick Hurd
    Rick Hurd Dec 13, 2010
    You may have a virus. Please update and run a full virus scan.
    What is the exact error code that it gives you before shutting down?
    Will your PC run ok in Safe Mode?
NinaE
    President:
  • 3,278 Answers
Hello.
Either you have a memory issue, a hard drive issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
Try your hardware diagnostics to see if the hard drive is failing. Upon boot, press F12 (usually) to load your diagnostics. Follow the prompts to test the hard drive. If faulty, you'll need to replace.
It's also possible that your Master Boot Record is corrupted. To fix:
First, restart your computer with the Windows XP setup disk in the CD drive. If you don?t have your original disk, borrow one or download a ISO image from a torrent site.
2. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
3. Once the setup loads, you will see the option to press R to repair a Windows installation.
4. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password.
5. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Also run the fixboot command to repair the boot sector with a new one.
Hope this helps.
Posted on Dec 13, 2010
My hp Compaq nx6120 can't starts. When I turn on screen the follow messages F10=ROM Based setup i pressed F10 but I can't go into bios. please help me!!
please help me!!
Jan 23, 2011 | HP Compaq nx6125 Notebook
When I turn on my Prosignia 144 it goes straight to a screen that says Compaq. Is it just doing that because it needs to charge or is it broken?
This is usually the post boot screen, most pc's/laptops show this before booting up, if its not going any futher then you may have a damaged instalation or just a damaged MBR.
If you google MBR fix you should have a good idea what you need to do
Jul 05, 2010 | Compaq ProSignia 144 (388433-004) PC...
The sd card reader in hp compaq nx6125 is not working
dear it is damaged...please replace....when this message show then memory card is damaged and not readable or not writeable.
Apr 23, 2009 | HP Compaq Business nx6125 Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario SR1000
Unless compaq displays that message when the computer goes into sleep mode, it could be a virus.
Nov 09, 2008 | Computers & Internet
Manuals
http://www.motherboard.cz/mb/soyo/SY-K7VEMPro.htm try this site for your manuals.
Let me know how it goes. thanks
Mar 09, 2008 | Soyo SY-K7VEM Pro V1.0 Motherboard
Compaq presario 5522
base on my experience with the old pc. it is very sensitive.the parts inside has corrusion it might be damage some chipsets.you harddrive can't detect by your system coz it might be damaged.try to get new harddisk just for diagnostic.i know that kind of pc needs startup configuration.it is very complicated.try to changed hdd first.good luck
Dec 02, 2007 | Compaq Presario 5000 PC Desktop
HP Compaq Presario SR1538X (PX799AA) PC Desktop Logo
73 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
