Question about HTC HD2 Smartphone
I use htc hd2 for T-mobile. i am in Nigeria now and use MTN nigeria. I have been trying to connect to the internet after having configured the gprs. It actually shows 3G connected and shows what looks like an active connection in the Notifications. however, all applications that rely on internet wont work. the browsers, facebook, you tube, etc.
Posted by lyndaoji on
Rommel Balcita
  • 749 Answers
Clear the IP address and port setting. Then try again
Posted on Oct 18, 2017
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Vodafone Live GPRS active, but not able to connect the web
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
Posted on Apr 29, 2009
Anonymous
  • 5 Answers
SOURCE: Wondering how to access optus 3G off a telstra phone
hey i have fixed this problem on my phone (htc touch hd, telstra) and this is how i did it- go settings, connections, go advanced tab down bottom, click select networks, click new on the top bar under programs that auto..... enter in OptusInternet (exactly like this).... then click modem tab down bottom then click new..... enter in OptusInternet again and chance cellular line bar to cellular line (GPRS, 3G)... then click next and for access point name type in internet.............. click ok ok x and then load up internet explorer and it should work
However the current problem i am still facing is opera wont run..... explorer will but opera doesnt load. just sits there untill it comes up with error 104 blah blah blah- still working out how to fix this as i hate internet explorer and opera is way better (going to try downloading opera 9.5 beta again and see if that works)
Posted on May 26, 2009
Anonymous
SOURCE: could not connect with wi fi
Go to settings and activate your wifi and say search networks. It gives a list of available networks. Select the network which you normally use and tap on it. you will get instantly connected. if you are connecting for the first time to a secure network click on the network . In the configure wireless network Connects to should have the option the internet. Then click next. It Authentication you need to enter the password needed to connect to the wifi router.Then click next & finish
sagar
Anonymous
  • 240 Answers
SOURCE: htc hd2 wifi not working says its not connected
the wifi function may be on but you have to tell it what network you want to connect to
Posted on Mar 09, 2010
pabitra mahato
  • 355 Answers
SOURCE: I can't connect my HTC wildfire phone to pc for
find the pc suite for your phone model no. download from net or go to nearest customer care & get it. connect it . save the access points on your phone and pc suite in computer. you will now be able to connect to pc for net.
Posted on Dec 15, 2010
My sim is not active to gprs
GPRS setting depend on the network you are using. In Nigeria, MTN GPRS setting is given below For your Nokia phone, the basic setttings are these; GPRS/WAP Settings Account Name = MTN GPRS or any other name IP Address = 10.199.212.2 Port = 9201 (for WAP) or 8080 (for HTML ) Username = web Password = web Access Point Name (APN) = web.gprs.mtnnigeria.net
So, please contact your service provider to give you your GPRS Setting.
Regards
Jun 29, 2011 | Nokia 3230 Cellular Phone
I want to configure my htc for gprs for internet browsing mtn nigeria
In Nigeria, the gprssetting for internet browsing will be sent to you shortly after inserting your simcard in your phone.
But, if the setting was not send to you, call mtn customer care on 180. Or you go to any of MTN office in Nigeria and the setting will be given to you on your phone.
Regards.
Jun 16, 2011 | HTC S710 Smartphone
How do i get a manual configuration for GPRS setting for my htc hd2 phone?
sir please call to the related simcard customer care and say the cellphone model number.and the phonenumber then they will send the gprs settings to your cellphone save the settings and switch off your cellphone and again switch on.then connect the data cable from phone to the computer for connecting the internet...........
Jan 05, 2011 | HTC HD2 Smartphone
G1 phone is locked due to wrong pattern,with no service to sign.
THEY ARE BUILT IN TO THESE PHONES TO STOP THIEVES FROM STEALING THEM AND SELLING THEM IN NIGERIA
Oct 30, 2009 | HTC G1
I need gprs settings for sagem my w-8
Even the manual configuration settings can be provided by your service provider. Go throughj the phone manual first and check what all GPRS settings are required. Just call the service provider again and ask the representative to dictate the specific GPRS settings you need for the phone. That must do it for you.
regards
Sandeep
Oct 27, 2009 | Lands Phones
GPRS conection
hi thanks for using fixya!
The GPRS setting could be acquired by contacting your Network Service Provider. They can send you the settings over the air or manually.
Regards!
May 03, 2009 | Samsung Blackjack SGH-I607 Smartphone
GPRS RELATIVE
Are the services subscribed to by your providers.
May 14, 2008 | Nokia 2600
HTC HD2 Smartphone Logo
127 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Marvin
Marvin
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
