Question about Sanyo DWM-2500 System
Hi, I want to know if it's possible to connect my computer to the Sanyo-dvd (DWM-2500) loudspeakers. If it's possible, could you tell me how? I can't find it anywhere. Thank you very much!
Posted by bassoferrer on
David Dunn
  • 8,546 Answers
In stereo, yes. At a minimum your PC should have a headphone output and/or a rear-panel stereo speaker output (usually 1/8" green), which is essentially the same. Get into the audio controls and set whichever you use to be Large Stereo speakers.
Get an adapter for the 1/8"-stereo-to-RCA-cable pair and attach it to the only analog audio input on the Sanyo.
Posted on Dec 14, 2010
Change region code to my Sanyo DWM 400, in order to read DVD of regions 1 and 4. I are in Mexico City.
Sanyo DWM-400
  1. Open tray
  2. Press 5, 7, 9, 2
  3. Select 0 for multi-region
  4. Close tray
if this will not work then. its not possible to change the region
Jan 17, 2011 | Sanyo DWM400 DVD Player
I have a Sanyo DWM-390 DVD player and I can't get the video on my TV. I have the DVD player going directly to my TV versus my cable box. I have the video and audio chord in the corresponding audio and...
3 possible solutions to your problem starting with the easiest:
1. The audio/video cable is bad. It is possible the video side of the cable has a short.
2. Inputs on the back of the TV are mislabeled or aren't matching up with how you are connecting or using the inputs. Feel free to post a picture of the back of the unit with your cords attached and I can tell you for sure.
3. Some dvd players require you to select which video output mode to use. Most of the newer ones come defaulted to hdmi output and might need a menu selection changed to output using component or composite outputs (whichever you are using). Composite will just have the red and white connector for audio and a single yellow connector for video. Component uses the same 2 audio connectors and then red, green, blue conectors for the video.
Let us know more detail and I can help further.
Jun 14, 2017 | Sanyo DWM-390 DVD Player
I need the 3 digit setup code for a DWM-380 Sanyo DVD player to work with my universal remote. I tried 649 and 654 to no avail. Please Help!!!! John Baker
Try 147 - that is one for Sanyo DVD players.
Also try 003, 007, 010, 020, 053, 057, 082, 102, 187, 166, 187, 214, 266, 511.
Hope one of those works for you. Be aware though that depending on the remote you are using, it may or may not be programmed with the right code for this Sanyo DVD player.
Anyway I hope this helps. Thanks for using FixYa.
Jan 06, 2010 | Sanyo DWM-380 DVD Player
Undefined region comes up when I insert any disc into my dvd play
This may be because it is region locked. The following will make the player region free and possibly solve your problem. By making your player region free you MAY be voiding any warranty the player has on it.
  1. Switch on, wait for "no disc"
  2. Enter 11233543254346
  3. Switch off
Apr 12, 2009 | Sanyo DWM-380 DVD Player
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
HOME THEATER CONNECTIONS
I get all the sound I need but I can't play the TV through the sound system. It is a samsung DB390. Can play DVD's through the system but not the TV. Any ideas?
Roger
Feb 17, 2008 | Sanyo DWM-2500 System
SANYO DWM-3000U combo dvd & vcr home theater system
I have a DWM 3000u that won't play some new DVDs. The movie is pixlated. Is there a firmware fix or do I need to buy a machine?
Lynda
Jan 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
DVD won't play: Err message
We have the same problem with our Sanyo DWM-3800.
Kal
Nov 18, 2007 | Sanyo DWM-3800 System
Sanyo DWM-2500 Subwoofer bass output
You cannot access the bass settings with the remote. The remote that comes with the DWM-2500 is Sanyo Part #RB-TS760MT
Oct 28, 2007 | Audio Players & Recorders
Sanyo DWM-2500 System Logo
Top Sanyo Audio Players & Recorders Experts
 Mikey
Mikey
ray gallant
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
