Question about Sanyo GPS
I want to update my sanyo navigation system. model nvm-4370
Posted by phalynx on
2 Related Answers
KhaKev
  • 20 Answers
SOURCE: How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
Posted on Mar 05, 2009
KhaKev
  • 20 Answers
SOURCE: my sanyo nvm 4370 video option say no video player installed
This unit only supports MPEG4/H.264 file. The files format has to be .MP4. This unit cannot play all MPEG4/H.264 movie files. Most movies out there are converted using DivX or XviD codec so if you need to convert them to this supported format. It will mostly cost you time if you found a free converter.
If you don't have time. You might try my basic hack to add a 3rd party media player that will play almost everything out there and it also supports sub-titles. You can check out my video on YT @ http://www.youtube.com/KhaKev.
Where can I buy replacement auto connecting cable and USB connecting cable for Sanyo nvm 4370
the only place i could find was amazon please check these out iff not contact sony and they will put you in the right direction
http://www.amazon.com/Sanyo-NVM-4370-4-3-Inch-Portable-Navigator/dp/B001F0RNRW
Jan 24, 2011 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
How do you get updates for this gps
After almost an hour of researching your question, I finally located the link to purchase updates for your NVM 4370.
(This page is well hidden)
Click here: http://bit.ly/beIKx0
If you found this information helpful, please give me a big thumbs-up when you rate my answer.
Feb 07, 2010 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Is there any update for the sanyo nvm 4370
http://us.sanyo.com/Navigation-Systems/Easy-Street-NVM-4370-Portable-Navigation
Pre-Installed Maps: Set up of the Easy Street Navigation System is simple because there's no software to download. Maps are pre-loaded and ready to go. Map data covers the US, including Alaska and Hawaii, Canada and Puerto Rico.
SANYO NVM-4370 Map Update DVD North America 2009-2010: Get accurate directions to wherever you travel including new roads, new sub-divisions, and current addresses. New and expanded coverage in over 159 cities, counties and metropolitan areas across the continental United States and Canada including Alaska, Hawaii, Puerto Rico and the U.S. Virgin Islands. You can confidently drive through unfamiliar or recently changed areas. This latest edition features over 6.18 million miles of navigable roads and an updated list of over 7.57 million Points of Interest to help you find the way to where you want to go quickly and efficiently.
Sep 17, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Seeking map updates for Sanyo NVM-4370 ...do they even exist? Purchased mine Oct 08, have done random searchs with no success.
Got this off a website
CAUTION - I called SANYO's customer service @ (800) 421-5013 to ask about map upgrades, getting maps for other countries for the SANYO NVM -4370. The answer: THERE IS NO CURRENT ABILITY TO UPGRADE EITHER SOFTWARE OR MAPS!!
Jun 29, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
I am trying to load the software for my Sanyo NVM-4370 GPS system
Had the same problem.. Make sure you have the right USB cord that comes with the device.. I was using the wrong USB cord.
Apr 05, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Option 2 (SD Card):
Feb 26, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Installing mio pocket on Sanyo 4370
Use SDFree method and assume you have extracted MioPocket on your PC's local drive
  1. Hook up your GPS to a PC via USB cable and note a drive letter
  2. Copy MioAutoRun, SDFree, and Media folders to the root of GPS FlashDrive (drive letter) above
  3. Open MobileNavigtor and rename MobileNavigator.exe to MobileNavigator_orig.exe
  4. Rename all 3 files begin with Miomap in SDFree folder to MobileNavigator (keep the extension intact)
  5. Copy all 3 files and MortScript.exe to MobileNavigator folder
  6. Unplug the GPS and launch MioPocket via the Navigation button. MobileNavigator on top is Sanyo GPS apps.
HTH.
Feb 18, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
GPS Logo
54 people viewed this question
Top Sanyo GPS Experts
Marvin
Marvin
Tom Chichester
Are you a Sanyo GPS Expert? Answer questions, earn points and help others
