HI, its the problem that your dvd/cd can not read dvd cd .
Think It could be a problem with the lens, you should try cleaning the lens, and clean all the
cable ribon,and also fit it tightly.
If you take a little risk but you can solve it self.
follow the instruction: Don't panic its very simply.
1. When running your pc , open the drawer.>
2. switch off the ac power
3. remove power cable & sata or pata cable
4. remove all the screw from the back side
5. press clip to open the font panel
6. reverse the cd/dvd rw
7. just remove the cover
8. clean the optical lance
9. remove all the ribon and clean by eraser or sharp blade.
http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
10. use a little ( not much )oil place on two steel shaft
11. cover all the equipment
12. now you can fit to your pc
If it does the same problem please change the cd/dvd rw because the lance has
defected.
Hope it will help you.
