Question about Lexmark X1270 All-In-One InkJet Printer
I plugged my printer into the usb port but it is not installing the printer
Posted by davisrichard on
Lexmark
  • Official Brand Answer
  • 3,344 Answers
You can easily download and install the Lexmark X1270 driver from the Lexmark website for free. NOTE: The Lexmark X1270 printer is supported on Windows operating system only.
Go to this link Lexmark X1270 Drivers. Select your operating system by clicking on change OS.
Click on FILTER.
Then click on Recommended Downloads.
Download, execute the file and follow the instructions on the software.
I hope this information has been helpful. Thanks.
Posted on Dec 14, 2010
Usb port not working
Printers are particular about which usb port they are plugged into, a virtual printer port is assigned to USB1 in the computer, when you select the printer port for it to use. You may need to plug the printer into each USB port, until you fine the USB port 1 which it works in, remember to always connect it to this same usb port, otherwise it will not work. There is only one USB port number 1.
Apr 10, 2013 | Brother MFC-7340 All-In-One Laser Printer
Not sure which port I should connect my printer to on my Dell hardrive
if it is a stand alone install for one pc, the USB port (any USB Port ) will be ok, just remember to install the cd before you plug the printer in, the install should tell you when to plug the pinter in. good luck and i hope this helps
Feb 09, 2011 | HP Color LaserJet 2600n Printer
When I plug it into the usb port nothing happens, it won't turn on, is there some kind of switch I need to turn it on?
iNSTALL PRINTER DRIVER.
PLUG IN THE PRINTER VIA USB
TURN "ON" PRINTER
IF NOT RECOGNISING THEN PROBLEM WITH USB CABLE OR USB PORT OR PRINTER PORT.
Jan 13, 2011 | Office Equipment & Supplies
Usb ports quit working on my hp netbook 1151nr mini
Recheck bios and verify usb ports are turned on.not sure how?just let me know ican walk you through this.RICHARDM69
Aug 24, 2009 | HP Mini Notebook
I can't install my 4200 printer/fax. i get to the part where it says plug in usb cable, and it doesn't go beyond that. the cable is plugged in
Just for fun, try this: abort the installation process. Then plug in the printer in any USB port. Does the computer see the device? It should and then ask for a driver. If the system doesn't see the printer, then make sure the USB port is all right. Plug in some other USB device, such as a mouse, into the port. Does the computer see it? If not, then the trouble is in the PC. If it does, then your printer or the USB cable is bad. You can also take the printer to another computer and plug it in to make sure that it's all right.
Jan 31, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer is not working.
Your computer should pop up and tell you that you've installed a new piece of equipment anytime you plug something into the USB port, since most peripherials are plug and play. If not, then it doesn't recognize the printer. You may have a bad USB port. Try plugging the wire into a different USB port during the installation process.
With Brother, you have to use their installation CD and follow their instructions. You can't hook up the wires till *after* the CD has walked you through their installation process.
Try reinstalling using their CD and a new USB port to see if it will work now.
Jan 06, 2009 | Brother HL 1440 Laser Printer
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
Computer won't recognize USB ports
If you are plugging a USB device into a different port it takes some time to recognize and install it - it re-installs for every port. There could be cable and/or port issues as well. Plug the printer into a USB port that the mouse does work on and allow several minutes for it to detect install it.
Dec 18, 2008 | Dell Dimension E521 PC Desktop
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer
It should not matter which USB port you use.Have you used the USB port you have the printer plugged into with anything else?
If you have a USB memory card try this on that usb port just to test the port is not faulty.
Feb 08, 2008 | Office Equipment & Supplies
Lexmark X1270 All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
