SOURCE: reflashing wyse s30 unit
It probably has to do with the version of CE client that is installed on the Thin Client. I have run into this problem before. The same Wyse clients can have different versions of CE installed. If the versions are the same then contact WYSE tech support to find what the error code relate to. BPCS
SOURCE: Wyse terminal does not boot
it's not recieving a strong enough signal.try this ,unplug the power supply and if there is a reset pin on this ,push it in.Alot of reset pins are very very small,make sure you look real close.Wait for about 30seconds and re try with power.
SOURCE: flashing cursor on wyse-55 termoinal
Yes, try another one.
Rory Cardenas
Midrange Repair and Parts
Alsip Il 60803
708-597-4222 x240
[email protected]
SOURCE: WYSE S10 thin clients; we are hearing from users
hi
where can I download the firmware for Wyse C10LE
Shine a flashlight on the dark screen to see if you barely
see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If so that proves your
video card is ok. The video will show on most systems when you reboot
without you having to do anything. Some systems will require you to hit the FN
(Function key) + F1 thru F12. Hold down the FN key then hit the correct
key for displaying on the monitor (F1 thru F12). The correct key will
normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
