SOURCE: Cannot connect using LG internet cube software
how can we install the modem driver correctly please help.. confuuuuuuused
SOURCE: limit or no conectivity problem
I understand that you are using the Windows Internet Connection Sharing to share your internet connection to your other computer.
If you don't have a router to share the connection then you are using Windows ICS connection.
When you enable ICS, the network adapter connected to the local area network is assigned a static IP address of 192.168.0.1.
You can check this site for more information
http://www.annoyances.org/exec/show/ics_xp
You can try to connect the two computers first without the internet connection.
Example : PC A 192.168.0.2
You can set the IP addresses manually, just set the tcp/ip properties and from that area you can set the IP address manually.
And for PC B 192.168.0.3
You dont need to set the ip address for the gateway and dns since you are just testing the connection of the two computer.
They should belong to the same workgroup example HOME and set the computer name to PC1 and PC2.
You can right click MY COMPUTER then select PROPERTIES then you will able to see the computer name.
To start the wizard
1.
Choose Control Panel from the Start menu.
2.
Click Network and Internet Connections, and then click Set up or change your home or small office network.
http://www.smallbusinesscomputing.com/webmaster/article.php/3293481
http://www.homenethelp.com/connection-sharing.asp
http://practicallynetworked.com/sharing/xp_ics/
SOURCE: Connects to Access Point but the internet cannot be found
I am having the same problem. My internet connection is at 96% and it connects and then disconnects while trying to access the internet.
SOURCE: Laptop cannot connect to internet outside company domain using wifi at home
typically at home you don't need any proxy settings configured within internet explorer. often in a work environment proxy settings can be applied.
if you think thar you have access to modify the settings do the following;
right click the IE7 (same for IE6) icon on your desktop select properties and select internet properties on the dropdown list.
left click the "Connections" tab
left click the LAN Settings button
deselect all of the ticks (most importantly the Proxy server part)
left click OK
left click OK
then open up IE normally and see if this has worked.
note of caution though; if as you suspect group policy is pushing the settings, next time you logon to the company LAN your changes may be lost and you will need to remove the ticks again.
also if you still get no joy try leaving the Automatically detect settings ticked with the proxy part unticked.
Try calling your provider. In my location, they send an sms, that has a config file, and it automatically installs all the settings required and Viola! u're ready to surf :D
This link provides a lot of information for WAP. I have posted the basic info below but if you go to the site you should get the answers that you are looking for specifically.
http://computer.howstuffworks.com/wireless-internet.htm/printable
Thank you for your ratings and votes on my research and advice for you. I hope this helps you out.
Stormi
Introduction to How WAP Works
Internet Connection Image Gallery
Cameron Spencer/Getty images
Wireless Internet can be built into your cell
phone or received through a wireless card. See more internet connection pictures.You and millions of other people around the world use the Internet every day -- to communicate with others, follow the stock market,
keep up with the news, check the weather, make travel plans, conduct
business, shop, entertain yourself and learn. Staying connected has
become so important that it's hard to get away from your computer and your Internet connection because you might miss an e-mail
message, an update on your stock or some news you need to know. With
your business or your personal life growing more dependent on electronic
communication over the Internet, you might be ready to take the next
step and get a device that allows you to access the Internet on the go.
