Question about LG (GDR8164B) Internal DVD Drive
Can my Medion MD90088 external dvd-rw-rw +/- drive be mused on my laptop? I've used it with my 1 gigabite processor desktop for the past few years,with great success. Thanks
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 624 Answers
SOURCE: Please Insert disk?
Hi Tool4theman, I have a CD/DVD r/w drive and it only says NEC DVD +RW. That is just the text the manufacturer has embedded in the device, not the results of any diagnostics. You've mentioned what program you are playing DVDs with but what are you playing your audio CDs with and are they commercial audio CDs? Have you tried running a diagnostic on your drive? Here is a link to the Sony CD/DVD diagnostic tool. Its meant for Sony drives but I have used this successfully on other drives in the past. When prompted for a blank disk us a CD. http://sony.storagesupport.com/cdrw/diagnostics.htm#dwn Let us know how it goes and don't forget to rate the posting.
Posted on Jan 03, 2007
Macbook pro disc drive ejects everything
Try using a cd drive cleaning disk. Costs around 15 dollars.
Dec 18, 2012 | Apple MacBook Pro Laptop Computer with...
Can I use dual layer dvd +r 8.5 gigabit for
Yes, you can back up your data or a disk image your whole hard drive.
Depending the amount of data you want to backup, you can use
CD 700 Mb of data
Single layer DVD 4.7 Gb of data
Dual layer DVD 8.5 Gb of data
Mar 08, 2010 | Gateway (5500652) (  5500652)...
Gateway mx3222b laptop ram upgrade problem
your computer does not support 1GB memory sticks. The max memory for that system is 1GB which would be 2 sticks configured as 512MB
see below for the specs (i bold, italics and underlined the main part)
Processor Intel® Celeron® M Processor 370
1 MB L2 Cache | 1.50 GHz | 400 MHz FSB Display Screen 14-inch Widescreen Ultrabright™ WXGA TFT Chipset Via VN800 Memory 256 MB DDR2 (1 × 256 MB) SODIMM
Total slots: 1 DDR2 slot | Available slots: 0 DDR2 slots
Expandable to 1 GB Video S3 Graphics UniChrome™ Pro IGP
Up to 64 MB shared VRAM Audio AC'97 2.3 Compliant Hard drive 40-GB 4200 RPM hard drive Optical drive DVD +/- RW Multi-Format Double Layer
Write maximum: 8X DVD+/-R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 24X CD-R and 16X CD-RW discs
Read maximum: 24X CD-R/RW/ROM, 8X DVD-R/RW/ROM, 4X DVD+/-R DL, RAM discs Media Reader 4-in-1 Digital Media Manager
Secure Digital™, Memory Stick®, Memory Stick-Pro®, and MMC™ Modem 56K ITU V.92 ready fax/modem Network 10/100 Mbps built-in Ethernet
802.11g integrated wireless (up to 54 Mbps) Interfaces
  • 2 - USB 2.0 ports
  • 1 - VGA external connector
  • 1 - RJ11 (modem)
  • 1 - RJ45 (Ethernet LAN)
  • Microphone jack
  • Headphone jAck
Pointing device Touchpad with vertical scroll zone PCMCIA 1 - Type I or Type II; Card Bus Battery 6-cell Lithium-ion Dimensions 1.1 to 1.24-inches (H) × 13-inches (W) × 9.7-inches (D)
28 to 32 mm (H) × 330 mm (W) × 246 mm (D) Weight 5.01 pounds
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
Chipset Via VN800
Expandable to 1 GB
Interfaces •2 - USB 2.0 ports
•1 - VGA external connector
•1 - RJ11 (modem)
•1 - RJ45 (Ethernet LAN)
•Microphone jack
•Headphone jAck
Weight 5.01 pounds
Mar 03, 2010 | Gateway Computers & Internet
I have a HP External USB CD/DVD R/RW drive. Stopped working.
First, try a new USB cable. Two, try a different USB port (if using a hub, directly connect to the computer). Three, check if there are any updated drivers or firmware for the drive.
(also make sure that the external drive is self-powered that the cord is undamaged and the power isn't surging or going into a brown-out. If it is one of the new bus-powered DVD drives, make sure that the computer has a good power source (not on battery for a laptop).)
Feb 27, 2010 | HP 8x External Double-Layer USB 2.0 DVD...
Where is the bluetooth-cable connector on the gateway mp8708. Thanks Heinz
I believe he's asking where to add the aftermarket modules: GABU-MP8708-0001 MODULEGACA-MP8708-0038 CABLE
Jan 11, 2010 | Gateway MP8708 Notebook
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Hello, i use an acer laptop,i have the philips DVD + RW drive in the laptop.but now for the past few days it has just disappeared,it does not show in my computer but it is still there in computer mana
The device may be disabled or is in conflect with something else. I would recommend to have the drivers uninstalled and reinstalled other wise reformat your hard drive. FFR (Full Format Restoration) don't forget to back up.
Apr 22, 2009 | Computers & Internet
Motherboard Replacement
I would check Ebay you may be able to find a replacement one for cheap.
Jan 07, 2009 | Gateway MX3560 Notebook
No dvd being read in my acer 4520 laptop
Since on a laptop the laser lens is right in the open with the drive open, it's easy to get it dirty. Try cleaning it with a cotton swab moistened with cleaner or isopropyl alcohol and see if discs read.
It's also possible you have a bad drive. Like any other electronic device, it is possible for a drive to "just quit working" properly. The problem with laptop drives is that they aren't all alike, so you can't just pick up and install a generic replacement like you could on a desktop machine. The easiest solution to a bad internal drive is to get a USB external drive, which has the benefit that you can use it on other computers as well.
Hope this helps!
Nov 20, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
GATEWAY 7330GZ PC NOTEBOOK
This link will provide you the required information.
Specifications
Part Number: 4997Gateway 7330GZ Notebook
System Gateway® 7330GZ Notebook Processor Mobile Intel® Pentium® 4 Processor 532 with HT Technology
(1MB L2 Cache | 3.06GHz | 533MHz FSB) Determine Your Processor Speed
Chipset Intel® 852GME Screen 15.4-inch Widescreen Ultrabright TFT WXGA
  • Maximum Resolution: 1280 × 800
  • Maximum Color Depth: 32-bit (16.7 million colors)
  • LCD maximum refresh rate: 60 Hz
Memory 512 MB DDR (1 × 512 MB), 333 MHz, DDR
Expandable to 1.5 GB Video Intel® Extreme 2 Graphics
Dynamic Video Memory Technology (DVMT) supports up to 64 MB shared video memory Audio PC2001 Compliant AC '97 Audio
Built-in Stereo Speakers Hard drive 80 GB HDD (4200 RPM) Optical drive DVD +/- RW Multi-Format
  • Write maximum: 8X DVD +/-R, 4x DVD +/- RW, 24x DVD+R DL, 24X CD-R and 10X CD-RW disks
  • Reads maximum: 8X DVD-ROM Disks, 8X DL/+RW, 24X CD-ROM disks
Media reader 6-in-1 Digital Media Manager
Compact Flash, Micro Drive, MultimediaCard (MMC), Secure Digital (SD), Memory Stick, and Memory Stick Pro Modem 56K ITU V.92 ready Fax/Modem Network 802.11g integrated wireless (up to 54Mbps)
10/100Mbps integrated Ethernet LAN Pointing device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces
  • 4 - USB 2.0 Ports
  • 1 - VGA External Connector
  • 1 - IEEE 1394 port
  • 1 - RJ11
  • 1 - RJ45
  • Microphone In
  • Headphone/Audio Out
Battery 8-cell Lithium-ion Dimensions 1.6-inches H × 14.0-inches W × 10.4-inches D Weight 7.5 pounds (8.65 pounds total travel weight)
Mar 24, 2008 | Gateway 7330GZ Notebook
LG (GDR8164B) Internal DVD Drive Logo
121 people viewed this question
Top LG Computers & Internet Experts
Ekse
Troy Staley
Troy Staley
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
