Question about Smeg F170 Pyrolytic Stainless Steel Electric Single Oven
I have a Smeg SA130P single oven. I have run a self-cleaning cycle. The cycle completed but, some hours later the lock indicator is still on and the door is locked. How do I get it unlocked?
Posted by j_backhouse on
D. Floyd Kolb
  • Smeg Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Posted on Dec 14, 2010
I want to know how to clean my self cleaning oven
Empty out the oven and turn on self clean feature. The door will be permanently locked until the cycle is completed a few hours later.. When you have access you simply wipe off the ashes on the walls and that is it.
Feb 03, 2016 | Ovens
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
Self cleaning oven won't unlock after cycle is complete
Unplug it for about 30 minutes, plug it back in and see if it unlocks. If not, then the latch, interlocking microswitch or control board is faulty. Also look for any bad connections (make suer the power is off before you start wiggling connections).
May 21, 2009 | Ovens
Self cleaning
Sometimes, according to what I've seen.  My theory is that the elements are probably covered in grime and this causes the damage.  As far as the control...I don't think that makes sense.
Never use cleaner on the elements..also causes damage.
A typical duty cycle for cleaning is 2- 2.5 hours.  Longer and you could burn them up, too.
Nov 28, 2008 | KitchenAid KEBC101 Electric Single Oven
Smeg oven cleaing cycle
Typically on any self cleaning oven, remove the racks and any pots/pans etc and wipe any excessive food stuffs etc from the bottom and set it for 3 hours.
Sep 17, 2007 | Smeg S1100MFX5 Electric Single Oven
Smeg F170 Pyrolytic Stainless Steel Electric Single Oven Logo
Top Smeg Ovens Experts
Paul Bade
Dennis Boxerman
Are you a Smeg Oven Expert? Answer questions, earn points and help others
