Cnet (CWR-854) Wireless Router (cwr854) Logo
Question about Cnet (CWR-854) Wireless Router (cwr854)
My CNet CWR-935 wont connect to the internet wont could be the problem?
Posted by domnicdbest on
5 Related Answers
Anonymous
  • 2961 Answers
SOURCE: cnet CWR-854 does not work
You may be advised to use an RJ45 LAN cable to try the following, then use the wireless connection when all ais up and running. The default Login ID and Password is ?root? with password ?1234?. This Wireless Access Point?s default IP address is 192.168.1.253, You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point?s panel for more than 10 seconds to reset its default settings back to factory default. If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
Posted on May 25, 2007
Anonymous
  • 46 Answers
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Posted on Aug 10, 2008
Anonymous
  • 6487 Answers
SOURCE: cnet CWR 854 Router
Try this another way of resetting the router, Press and hold teh reset button for 30 seconds while the power is ON then after 0 seconds unplug the power of the router for 10 seconds , then check again if the lights WAN and WLAN lights are still OFF, if its still OFF you can try calling this number for further assistance for this router 1-877-787-8749 so atechnician can walk you through in checking if this router si really bad already or still can be fix....
Posted on Oct 16, 2008
Anonymous
  • 3 Answers
SOURCE: I want to connect cnet cwr 854 as an Access point AP,
ENABLE YOUR WDS ENTER THE MAC ADRESS CIENT
Posted on Feb 06, 2009
SOURCE: How to use my Cnet CWR-854 Router as a wirerless antenna for pc.
You can't really use a router to connect to another router, you can sometimes use them as an "Extender" for range, but not as a WiFi card, they simply aren't made to operate that way.
Posted on Feb 19, 2010
I cant install my cnet wireless g router cwr-854
you should contact your internet provider for professional advice. it's most likely free and faster than asking nerds on the internet who doesn't know anything about your specific router-model ;)
cheers
What is it used for?
You can use this wireless router to connect different wireless devices together. Each device with a wireless network card (computer, phone, gaming system, printer, etc.) can connect to the router without a cable. This will form a network where information can be shared.
The main purpose people use this for is to connect their network to the internet. As long as the router is connected to your internet, every other wireless device can also connect.
Thanks,
Pat
Cannot connect to internet, already configure my wireless CWR-854, thru 192.168.1.254, when im in internet, my deafault gateway is 192.168.1.1, please help
online user manual is here http://www.cnet.com.tw/download/cwr-854.htm If you goto page 37 it show the dhcp range . Make sure your pc cofiguration is set to dhcp - automatically obtain and IP and DNS - this is explained on page 10/11 try this Start>run{vista/7 search box}>cmd>ipconfig /release Start>run{vista/7 search box}>cmd>ipconfig /renew see if that produces the correct info
Trying to access 192.168.1.254 for siemens se567, followed advice to go to run and cmd ping, don't understand other go to access point, my situation is the older couple I live with have wirless internet in...
The internet connection has a security that's why you can't access the internet. The only thing you have to do is to know the wpa password of the router.
This router has a default username and password to configure all the settings. This is the manual for Cnet CWR-854 Router:
http://www.cnetusa.com/eng/Manuals/Wireless/CWR-854/CWR-854%20ver%20F%20User%20Guide.pdf
It seems that the router is already configured by an authorized person, the best thing you should do is contact the authorized person that knows everything about the router.
2answers
Is there a conflict between linksys BEFW11S4 router and CWR-854 cnet router?
No problem at all. The router can function as bridge with no conflicts with other routers.
Cnet CWR 854 Router
Let me know
comier957
CWR-854 router
Type in the address of your router - you say that is set to192.168.1.254 and you will see the config page( after logging in ) for your router. This is more usually 192.168.1.1 though .
Top Cnet Computers & Internet Experts
 Mike M
Mike M
NOEL
NOEL
matt
matt
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
