SOURCE: troubleshooting sony handy ccd-trv 107e
The first thing you should try is removing the batteries for 20 to 30 minutes to reset the unit. If this does not work push in on the cassette mechanism at the top while trying to eject. Also check the tape compartment cover screws to make sure they are tight. Any misalignment in the cover mechanism will cause binding which will create the problem you describe. Finally, and I know this will sound unusual, slap the unit on the cassette side. Forcefully but not enough to break anything. This procedure has been helpful many times with similar problems. I know it is not sientific but hey if it works. If none of the procedures solves your problems you may need professional help. The following websites offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck
SOURCE: "reinsert the cassettee" error in Sony HandyCam CCD-TRV 438E.
The camcorder most likely is not detecting the tape, you have a bad sensor and these sensors all come on a flex type board and the flex board is mounted on the chassis surface. This will mean that the entire mechanism will meed to be diassembled, and is a very big and costly job. My opinion is that this repair will run you abut 250 to 300 bucks and this camcorder is not worth this as new camcorders are under 200 bucks. Good Luck
SOURCE: Blank screen
Hi: Check and see if there is an X as in escape out of the Menu Mode. If there is no X,then look fo OK. Good Luck. zeffy57.
SOURCE: LCD display is not working
the flex wire of lcd monitor has being cut.....and a message 'cover is not open' there switch inside the cover of the lens that is losing contact....
SOURCE: Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
its because sony is recall for Sony Digital camcorder TRV22
