Question: Is this old timer that started malfunctioning?
If this is older timer, that worked correctly before, then the timer has gone bad.
You can reset timer, and then re-programming.
But without knowing which timer, it's hard to say if timer has reset button or if you hold down two buttons to perform the reset.
Add a comment with better description of timer: plug-in, outdoor, in-wall, programmable, or dial-type.
Describe buttons and location exactly.
Is there a switch on the side? Or a slide button on top.
Is outlet 3-prong? How many outlets? Are outlets on front of timer or sides?
Nobody carries repair parts for old timers.
I can probably find new model with same features
If this is new installation, and timer replaces wall switch, it sounds like the wiring is wrong or timer is busted.
Again I need a very specific description of the timer, and the timer wires, and the wires inside box, and the switch it replaced.
There are 100's of timers out there, in all shapes and sizes, with different features ... and I know most of them.
But need more info.
http://picclick.com/Amazon/Home-Improvement/Electrical/Timers/
