Vizio M550NV 55 in LCD HDTV Logo
Posted on Dec 13, 2010
Vizio m550nv led lcd tv. Problem began a couple weeks ago. Tv turns on and works for 30 seconds, turns off and flashes front vizio logo orange/white as if tv is turning on and off, flashes for 2-3 minutes and then continues operation as normal. Occurs 9/10 times tv is turned on.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4350
Points
15
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
scott smothers
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 05, 2013
scott smothers
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4335
Points
You need to unplug it hold power button in for 30 seconds then plug it back in and let it go threw start up when its done hit the power button.
How to test Tcon and other board on Vizio television. When I first connect power logo is bright orange, then slowly dims.
That isn't a timing control board issue, see if you have PSON voltage for starters, if you do then test the various power supply voltages, it could be either the main or power board giving issues, but I would bet on the power supply is bad since the logo comes stays on
2answers
What are the symptoms of a bad psu for vizio m550nv
Vizio 0500-0612-0030 Power Supply / LED Board for M550NV
www.shopjimmy.com/vizio-0500-0612-0030-power-supply-...
ShopJimmy
$77.42 - ‎Out of stock
This Vizio 0500-0612-0030 Power Supply / LED Board for M550NV (0500-0612-0030) works for these ... The odds we'll get it soon: Bad (What does this mean?).
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply ...
electropartsonline.com/vizio-55-m550nv-0500-0612-0030-lcd-power-su...
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply Board Unit Motherboard. ... Any tears or bad connections between boards must be replaced FIRST. 2.
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair ... I can not get it to power on so I ...
Vizio m550nv amber light is on but tv will not power on
? 6:13
DiY How to Fix led / lcd Vizio TV service repair - no powerservice repair review guide no red blinking led ... Theorange/amber light turns on when plugged in. But the TV won'tturn on after that (the light does not turn white).
Vizio TV logo Flashing (Blinking), TV will not turn on, not ...
? 4:01
https://www.youtube.com/watch?v=MDzCzZdgbdg
Jan 5, 2012 - Uploaded by Leo P
This is model XVT3D424SV, I was watching a DVD, I switched the input to TV, tried to connect to netflix, it was ...
HOW TO FIX VIZIO TV - What causes no power - YouTube
? 5:53
https://www.youtube.com/watch?v=5k1Mc1f6O3E
2answers
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
