Apparently no, it does support only Windows 98 / NT 4 / Me / XP. However, here is a thing you can try if a program cannot be run under Windows 7 because of compatibility issues, which is the case with Print Master Platinum 15. You right click on the executable file that will install the application and click Properties. Select Compatibility tab and check Windows XP SP3. If it installs do the same for the EXE file that will run the application. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
