Question about Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr
How do I program a Noma N1506 timer? - Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr
Posted by virtronics on
Anonymous
All Woods timers and manuals
ttp://waterheatertimer.org/Woods-timers-and-manuals.html
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Posted on Dec 12, 2010
2 Related Answers
Anonymous
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Posted on Dec 14, 2008
Anonymous
SOURCE: I have a Noma timer
Open following link to identify timer with manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Manual for Intermatic/Noma 1506
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 10, 2011
NOMA 1000 watt Photoelectric Timer manual
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1502
2) If timer has gone defective, then N1502 has 1 year limited warranty.
Timer is rated for 8 amps.
125 volts x 8 amps = maximum 1000 watts
2-prong output.
3) For heavier duty timer, with 3-prong grounded output, choose N1506 timer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 04, 2012 | Hardware & Accessories
052-8835-2 Noma Block heater timer
Copy following link to identify various timers and download possible manual. Timer was originally made by Intermatic.
http://waterheatertimer.org/pdf/Intermatic-HB65R-timer.pdf
N1506 is 2-button timer and is called a block-heater timer.
This timer has 1 year limited warranty through Coleman.
http://www.colemancable.com/contact-us/technical-support/
Nov 22, 2012 | WOODS INDUSTRIES 2001 OUTDOOR MECHANICAL...
Instructios model #1508
That timer does not appear in my files, under Noma, or under 1508, or under any other brand.
Nor does N1508
There is N1507, N1502, N1506,
Copy following link to identify same-similar timer and download possible manual.
GE makes many timers with 15xxx product numbers:
Including: 15087, 15086, 15081-4, 15088, 15089, 15086
http://waterheatertimer.org/GE-timers-and-manuals.html
Add a comment and describe timer in detail for possible additional assistance
Nov 03, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I have a Noma timer Model N1506.I do not have a manual to know how to operate or set the time. Need help,please. Thanks, Eric [email protected]
Feb 10, 2011 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How to set the Nordik TM-065? It was bought for
The Nordik TM-065 timer looks similar to Woods/Noma N1506
http://www.advancedtimer.com/TM-065.html
Plug timer into outdoor receptacle.
Press Time button until correct time displays.
Dot on display is for pm hours
Nordik appears to be on the 24 hour clock instead of am-pm
Set operation of timer by pressing Mode button.
P flashes for program mode.
Press time button until starting time displays.
Press Mode again and E flashes.
Press time button until finish time displays
Press Mode button to exit programming.
Dec 17, 2010 | Woods Outdoor Lighting Timer
How to reprogram my Woods N1506 Timer
Manual and image for Woods/Noma N1506 outdoor timer
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
Timer is only set to nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Dec 13, 2010 | Woods Outdoor Lighting Timer
How to program my Woods N1506
FOR MANUAL OVERRIDE
Dec 13, 2010 | Woods Hardware & Accessories
Noma timer - digital three buttons - one for time & two for mode & ? but I can not figure out how to work it - HELP!!!!
Noma/Woods timers are re-packaged under other names and numbers, and appear across several brands.
I don't show a 3-button timer except for Stanley
Stanley 3 button timer:
http://www.amazon.com/Stanley-38468-TimerMax-Extreme-Temperature/dp/B0020ML758
Westinghouse manual seems to match the Stanley timer
http://waterheatertimer.org/pdf/28468_TimerManual.pdf
Woods timers and manuals are shown on page below:
Woods has 2-button timer N1506
Woods has 1 button timer N1502
http://waterheatertimer.org/pdf/Woods-N1502-manual-english.pdf
UPM makes 2-button timer
http://waterheatertimer.org/pdf/DT523-Manual.pdf
Write down what displays when each button is pushed, and then add a comment and I'll try to decipher the buttons.
Dec 12, 2010 | Hardware & Accessories
I have a Noma outdoor timer at the top it has time PM then a button that says time & one says number on back 1915774 & 0550 Mode model number n1506 how do I set it to come on and off re: Xmas...
Woods 49122/N1506 manual.
Your description sounds similar to timer shown in manual.
If this is not your timer:
Woods makes a lot of timers with more than 1 number depending on who packages and sells timer.
Here's a link to Woods timers that might help you identify:
Nov 30, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Solar Noma 7 Day, 6 Event Outdoor Timer - Easy To Use +warr Logo
30,894 people viewed this question
Top Solar Hardware & Accessories Experts
Sheldon Dedek
STEVE SPAM REMOVER
ray gallant
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
